2001 deville brake lights
Results 1 to 8 of 8
Electrical Technical Information Discussion, 2001 deville brake lights in Item Specific Cadillac Discussion; Need some help. 2001 deville no brake lights. all othes work brake lamp fuse good. Service electrical system on dash. ...
    njmont is offline Cadillac Owners Member
    Automobile(s): 2001 deville
    Jul 2012
    1
    Need some help. 2001 deville no brake lights. all othes work brake lamp fuse good. Service electrical system on dash. no codes. brake switches seem good any advice appreciated. thanks
    sdt1985 is offline Cadillac Owners Member
    Automobile(s): 1997 Seville SLS
    Jun 2009
    Texas
    53
    Re: 2001 deville brake lights
    I'm having the same problem with a 97 seville. Mine has two parklight fuses in the trunk that I have power to and I'm about to trace the wiring to the taillights. There is a splice on my wiring on the left trunk hinge that is supposed to be suspect. Let me know what you find. Good luck and may the electrical Gods be with you!
    Jun 2009
    Texas
    53
    I had an epiphany... The tail lights are not going to work in the sunlight with the twilight sentinel. A couple of pieces of tape over the light sensor on the dash and presto tail lights!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,936
    The OP's brake lights have nothing to do with Twilight Sentinel. No one has answered the OP's question - you went off on an entirely different problem............
    For the OP........ Your first course of action is to check the brake lamp bulbs themselves - if one filament burns out it sets the message. Beyond that, you're in the wiring checkout business. Do not overlook dirty bulb sockets and/or corrosion of the contacts.
    BTW......... Welcome Aboard !!!
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    2000-2005 deville tail lights are LED and are not accessible or serviceable ... i would think that something else is going on if both went out at the same time ... fuse/relay issue maybe, or a harness unplugged
    Feb 2006
    55,936
    2000-2005 Deville tail lights are LED and are not accessible or serviceable
    That's good to know........So is there a LED lamp driver system ?
    Sep 2007
    Wilmington, NC
    13,986
    I'm not very familiar with the system. I think it's pretty simple tho.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by njmont View Post
    If you have a SERVICE ELECTRICAL SYSTEM message on the DIC, there is a code present. Not all 'external' code readers can display "B" or "C" or "U" codes.
    Try displaying your codes using this method:
    http://www.cadillacforums.com/forums...-sevilles.html
    Does your cruise control operate as expected?
    Do your fender mounted brake lamps flash as expected when you activate the hazard flasher?
  11. Remove Advertisements
