Results 1 to 2 of 2
Thread: '68 de ville starter/electrical SNAFU
    donkeyparty is offline Cadillac Owners Member
    Automobile(s): 1968 Sedan de Ville
    Jun 2011
    I replaced the bulbs in the rear reading lights
    'engine temp' light came on - and has remained on ever since
    [whether the key is in the ign or not].
    battery went completely dead after that
    I replaced it with a good used truck battery {have kept it unhooked}
    15-20 attempts at starting - none have worked
    despite testing and recharging the battery [after sitting for a few weeks at a time
    so ... I took it to a mechanic [who kept it for 2 weeks] -
    he told me it was a bad connection at the alternator.. I drove it home
    the engine temp light came on 3 days later and it's been downhill ever since so to speak...
    anything anyone's got will be more than I have,. thanks!!
    Garys's Avatar
    Garys is offline Cadillac Owners Fanatic
    Automobile(s): 1968 CDV / 1970 FWB /1979 FWB / 1995 Eldo
    Aug 2007
    San Diego
    228
    Re: '68 de ville starter/electrical SNAFU
    I would check the voltage regulator. One of the points inside could be sticking, causing a back feed, even with the key in the off position. Tap on it with the butt of a screwdriver and see if the light goes out. I am thinking the engine temp. is actually your alternator light. If the engine temp light is on, usually a warning buzzer comes on too (past experience). Maybe the two warning lights got crossed somewhere along the way.
  • You may not post replies
