turn signals randomly quit working
Results 1 to 6 of 6
Electrical Technical Information Discussion, turn signals randomly quit working in Item Specific Cadillac Discussion; New owner to a 93 sedan devile and the signals were randomly working and now have completely stopped checked the ...
    bigr86 is offline Cadillac Owners Member
    May 2012
    6
    New owner to a 93 sedan devile and the signals were randomly working and now have completely stopped checked the fuse under the dash and its good could it possibly be the lever?
    Feb 2003
    california
    69
    6,643
    Re: turn signals randomly quit working
    If this car uses a normal flasher relay, swap the hazard relay for the turn signal one. If that fixes the signals, get a hazard relay whenever. Appears to be a BWD brand, part number FC 536
    May 2012
    6
    How hard is it to swap? And where are they located?
    Feb 2003
    california
    69
    6,643
    Turn on the 4 way flashers and locate the clicking under the dash. That will find that flasher. The turn signal flasher is usually clipped to the brace that holds the steering column. most times to the right side of the column.
    May 2012
    6
    Well I found the flasher relay and think I see the turn signal realy but it looks like I have to remove the fuel data center to get to it.
    May 2012
    6
    Fixxed thanks for your help and I did have to remove the fuel data center was right behind it turned out it was loose and still working although it looked slightly larger then the relay for the hazards so not sure if it would have worked.
  9. Remove Advertisements
