84 fleetwood brougham voltage regulator
Results 1 to 3 of 3
Electrical Technical Information Discussion, 84 fleetwood brougham voltage regulator in Item Specific Cadillac Discussion; does anyone know if this component is built into the alternator on the 84's 4.1L or if it is something ...
    84 blacked fleetwood is offline Cadillac Owners Member
    Automobile(s): 1984 fleetwood brougham d'elegante
    May 2012
    34
    Question84 fleetwood brougham voltage regulator
    does anyone know if this component is built into the alternator on the 84's 4.1L or if it is something external that can be swapped out on it's on?? thanks for the help, i've been having some power issues over here
    Feb 2003
    california
    69
    6,613
    Re: 84 fleetwood brougham voltage regulator
    Its inside the alternator. Most times low output can be corrected by tightening the smog pump belt after loosening the alt. belt 1st. Then once tight, tighten the alt. belt. If the smog pump belt isn't tight, the alternator will slip above idle, eventually causing a weak/ dead battery. If the smog belt has been slipping for awhile, it will be glazed and will need replaced.
    Feb 2003
    california
    69
    6,613
    I presume your issue is fixed? Posting what fixed your car can help someone else!
