02 Escalade-VERY slow window
Results 1 to 2 of 2
Electrical Technical Information Discussion, 02 Escalade-VERY slow window in Item Specific Cadillac Discussion; I have an 02 Escalade, and my passenger window has been getting slower and slower going up/down. Any suggestions as ...
    arejaye5000 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Escalade
    Oct 2011
    Lake County, IL
    35
    I have an 02 Escalade, and my passenger window has been getting slower and slower going up/down. Any suggestions as to what's going on? Need to be cleaned or is the regulator going out?
    Thanks!
    78seville455's Avatar
    78seville455 is offline Cadillac Owners Member
    Automobile(s): 1978 Seville 455 powered project
    Apr 2012
    Crete Il
    37
    21
    I would say clean and lube all the regulator parts just in case it's drying out. If the problem persists after that I would check the voltage getting to the motor, and also check the amperage draw. It may not be getting proper voltage, due to a bad switch or relay. Or the motor may be going bad..... Which would cause high amp draw.
