What is the hose and plug on the passengers side on dash in 1987 Sedan Deville
Results 1 to 2 of 2
Electrical Technical Information Discussion, What is the hose and plug on the passengers side on dash in 1987 Sedan Deville in Item Specific Cadillac Discussion; New here to the site. I just got done replacing my 4x6 speakers in the dash in my 1987 Sedan ...
    mizatt32 is offline Cadillac Owners Member
    Automobile(s): 1987 Sedan Deville
    Apr 2012
    6
    New here to the site. I just got done replacing my 4x6 speakers in the dash in my 1987 Sedan Deville and before I started I disconnected the battery because I knew the doors would be open and I didn't want to run the battery down. Well when you replace the dash speakers you have to take the whole top part of the dash apart, which I did and I had to disconnect a plug on the passengers side as well as disconnect what looked like a hose which was right next to the plug. Well when I went to put the dash back together I realized I didn't pay attention to which way the plug should go on and it can actually plug back in either way so it was a 50/50 guess and I also wasn't able to get that hose back on super tight, it was only put back in partially, but it is back on. Then when I hooked my battery back up my temperature gauge was set at auto and on 75 degrees but it wasn't blowing any air at first but then it started to eventually blow air. I'm wondering what that plug is for and what that hose is for. Any help would be appreciated.
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    Its a AC line what u do when u put the front speakers on your supposed to slide the top dash board to access the speakers .to get it back on reach under the top dash and connect the hose then slide the top dash back on
