2003 STS Lock/Sunroof/Elec Issues
Results 1 to 9 of 9
Electrical Technical Information Discussion, 2003 STS Lock/Sunroof/Elec Issues in Item Specific Cadillac Discussion; Leaving the office today the SES light on my car came on. Was not on when I parked this morning. ...
    Death-Speak is offline Cadillac Owners Member
    Automobile(s): 2003 Seville STS
    Nov 2009
    27
    Leaving the office today the SES light on my car came on. Was not on when I parked this morning. My sunroof and door locks do not work now. The actual button or the fob neither work. Its dark and cold so I'm not going to work on it tonight. Besides checking the fuses where should I start?
    Any guidance is greatly appreciated.
    Thanks
    Nov 2009
    27
    Thanks
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,630
    Re: 2003 STS Lock/Sunroof/Elec Issues
    Is the Valet Switch in the glove box on or off ?
    Your car has a built-in trouble code reader/scanner.............
    STUDY the sticky post ^^^ "How to pull codes" just above this thread on the main Seville page. Practice but do not "clear codes". Write them all down, whether each is Current or History, and return to the sticky and open the link with "obd2" in the address - that will take you to a Master Index of all trouble codes - write down all definitions of codes found and post it all here.
    EDIT: I just found your identical post down in Electrical - another Moderator will merge these in order to keep everything in one place...........
    Feb 2006
    56,630
    This is answered in your identical post up in Seville. Please don't double post - answers begin coming in and it's difficult to keep abreast of two threads, much less one. I'll have the Forum Moderator merge this with the one in Seville.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    Quote Originally Posted by submariner409 View Post
    and
    Nov 2009
    27
    Sorry I missed the sticky. It's been a long time since I've been here. The forum has changed a bit.
    I did verify that the valet switch is in the off position.
    Other things: The gas tank and the trunk won't open either. Gas lid not popping is a problem lol.
    I'll peruse through the sticky and find out what I can about the codes.
    Thanks
    DS
    ---------- Post added at 08:02 PM ---------- Previous post was at 07:05 PM ----------
    Here are the codes it displays:
    abs c1221 history - Left Front Wheel Speed Sensor Input Signal is 0
    abs c1225 history - Left Front Excessive Wheel Speed Variation
    abs c1228 history - Right Rear Excessive Wheel Speed Variation
    abs c1232 current - Left Front Wheel Speed Circuit Open or Shorted
    abs c1286 history - Steering Sensor Bias Malfunction
    abs c1287 history - Steering Sensor Rate Malfunction
    abs c1288 history - Steering Sensor Circuit Malfunction
    abs u1056 history - Loss of Communications with RSS
    abs u1016 history - Loss of Communications with PCM
    abs u1000 history - Class 2 Communication Malfunction
    amp u1300 current - Class 2 Short to Ground
    ddm b1621 history - *not on list*
    ddm u1713 history - Loss of Front Door Module to Window Motor High Speed Comm.
    ddm u1255 current - Class 2 Communication Malfunction (Serial Data Line Malfunction)
    dim u1255 current - Class 2 Communication Malfunction (Serial Data Line Malfunction)
    ipc u1000 current - Class 2 Communication Malfunction
    ipm u1255 current - Class 2 Communication Malfunction (Serial Data Line Malfunction)
    msm u1000 history - Class 2 Communication Malfunction
    pcm p0101 current - Mass Air Flow (MAF) Sensor Performance
    Nov 2009
    27
    So I'm assuming the short to ground or the communications malfunction are causing the issue. I googled these and didn't really come up with anything.
    Thanks
    DS
    Nov 2009
    27
    Verified that its not a fuse. I read on similar models that there are control modules for each area in the car that possibly connect back to a primary module via wiring harness. These are maybe routed around the floor and seats? I'm in foreign territory so any guidance is appreaciated. Thanks
    Nov 2009
    27
    Turned out the battery had a bad cell and didn't have enough juice to run all of the accessories in the car. It took a trip to the local GM dealer to figure that out. Replaced battery and everything works again.
    Thanks for all of your help.
  12. Remove Advertisements
