2003 SLS comfort control LED lights (any ideas?)
Results 1 to 2 of 2
Electrical Technical Information Discussion, 2003 SLS comfort control LED lights (any ideas?) in Item Specific Cadillac Discussion; Hi, the comfort control lights are out only where it reads the temp and says off. they are the only ...
    garypearson is offline Cadillac Owners Member
    Automobile(s): SLS 2003
    Dec 2011
    1
    Hi, the comfort control lights are out only where it reads the temp and says off. they are the only lights out.All else works good and the temp control still works.they just do not light up. any ideas would be appreciated.
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    You mean the climate control readout where it goes from 60-90? If so then you probably need a new climate control module nothing special just a direct swap and they go for rather cheap on eBay.
