coil problem
Results 1 to 2 of 2
Electrical Technical Information Discussion, coil problem in Item Specific Cadillac Discussion; wire coming from the ignition when disconnected from the coil reads 12.42 volts. when i connect it to the coil ...
    bill henry is offline Cadillac Owners Member
    Automobile(s): 1962 sedan deville
    Feb 2011
    horseshoe lake,arkansas
    70
    25
    coil problem
    wire coming from the ignition when disconnected from the coil reads 12.42 volts. when i connect it to the coil the voltage drops to 6.19 volts. no voltage out of the neg. side of the coil. do not have any spark from the coil.
    Feb 2011
    70
    25
    Re: coil problem
    found problem. not in coil, problem in the distributor. vacumm plate had a lot of movement in it. to much movement ,not alouing the points to open and close. got new distributor on the way.
