1970 Gen light always on when engine running, charging system is fine
Results 1 to 4 of 4
Electrical Technical Information Discussion, 1970 Gen light always on when engine running, charging system is fine in Item Specific Cadillac Discussion; Here's a good one, hopefully this will help somebody someday. This applies to 1970 Cadillac, possibly other years. If your ...
    intragration's Avatar
    intragration is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Coupe DeVille, 2002 Eldorado Collector Series
    Feb 2008
    Northlake, IL
    198
    Here's a good one, hopefully this will help somebody someday. This applies to 1970 Cadillac, possibly other years. If your gen lamp is always on when the car is running, and you've checked your charging system and it's working fine, check the gauge/trans fuse. The way the gen lamp works, it gets power from both sides of the circuit, and if there is an imbalance in power between sides, it will illuminate. If the gauge/trans fuse is blown, it's not getting power from that side, so the lamp will illuminate even though everything else is working fine. Be aware that SOMETHING caused that fuse to blow, and this root cause should be tracked down. In my case, I believe it was due to a failing battery connector on the back of the alternator causing high resistance and possibly overcharging.
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    544
    Re: 1970 Gen light always on when engine running, charging system is fine
    1970, that can't be right, it had a candle that lit up, they didn't have electricity back then! lol
    londonslimos's Avatar
    londonslimos is offline Cadillac Owners Member
    Automobile(s): 73 calais,
    Oct 2011
    yellville arkansas
    54
    42
    thanks my problem solved
    Feb 2003
    california
    69
    6,663
    It can also be lit dimly and still charge. That is most likely a failed diode trio within the Alternator.
  7. Remove Advertisements
