I have a 1981 cadillac Seville and
I recently replaced the ECM as it was internally burnt, and it was causing the engine to backfire and missfire as well as stalling at idle and making the MPG panel go crazy with numbers
With the new ECM installed, the service engine soon light turns on and off at times as well as the coolant warning light, the engines idling rises very high but comes back to its normal idling level after a while. The MPG panel shows strange numbers at times such as " IC and 0.189 " . I have performed the diagnostic check-up on the ECC , but no trouble codes have appeared.
Please let me know if you have any solutions to this problem.
My email address is
lugaseng@mweb.co.za
