2000 DeVille A/C Malfunction
Results 1 to 4 of 4
Electrical Technical Information Discussion, 2000 DeVille A/C Malfunction in Item Specific Cadillac Discussion; I've recently had some audio work done (by Best Buy) to the Caddy. I don't think it's the cause of ...
    Jamjohnson2 is offline Cadillac Owners Member
    Automobile(s): 2000 DeVille (Burgundy w/white top)
    Aug 2010
    31
    14
    I've recently had some audio work done (by Best Buy) to the Caddy. I don't think it's the cause of the problem, but now the AUTO function doesn't work on A/C. Also, air doesn't flow out of the upper portion. I could place the A/C in any spot and the defroster and feet always blow. Any help?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: 2000 DeVille A/C Malfunction
    Quote Originally Posted by Jamjohnson2 View Post
    Get any Diagnostic Trouble Codes from your car's built in code scanner/reader system. Use the sticky post ^^^ "How to pull codes". Study, practice, write them all down, noting whether each is Current or History, then return to the sticky to open the proper URL link for your year. That will take you to a Master Index of all P,B,C, and U trouble code definitions.
    This may be a blend door actuator fault, and that will set trouble code(s).
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    A couple of questions for you...
    When you first start the car do your here a rhythmic ticking sound that lasts for about 10 seconds coming from the area behind the radio?
    With the HVAC fan on high.... press the up or down arrows on the switch labeled "Mode" on the HVAC panel is the airflow directed as commanded to the defrost then to the dash vents and then the floor vents or is it always stuck on one position. If it doesn't move do you here any ticking noises... like a stripped plastic gear coming from behind the radio?
    Aug 2010
    31
    14
    Quote Originally Posted by 00 Deville View Post
    There is no ticking noise and it is always stuck in one position. I will pull codes tomorrow.
  7. Remove Advertisements
