1999 Escalade Battery Drain Problem
Results 1 to 8 of 8
Electrical Technical Information Discussion, 1999 Escalade Battery Drain Problem in Item Specific Cadillac Discussion; i have a 99 Escalade and i have a problem with the battery going dead. It keeps shorting out the ...
    Stoiz11 is offline Cadillac Owners Member
    Sep 2004
    53
    i have a 99 Escalade and i have a problem with the battery going dead. It keeps shorting out the 4wd actuator. If i dont drive it for a day, the battery goes completely dead. Anyone else have this problem? I think it is in the 4wd Moduale but before i worked on that i just wanted to make sure no one else had this problem. I know its not the radio, we pulled all the fuses the car has. It might be the alarm too? Let me know, driving me nuts.
    ESCO_BEEF is offline Cadillac Owners Member
    Apr 2004
    T.
    37
    19
    Re: 1999 Escalade Battery Drain Problem
    I had the same problem if I where to listen to the radio without the car on for 20 min or leave the car parked for a day or two I know i would need a Boost my problem was 2 dead cells in the battery I ended up picking up a new battery, problem solved. U might want to get the battery tested (load test) I think the dealer or shop will do it no charge if u ask them if they sell batteries
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,291
    If you have not replaced the stock battery I would start there, the stock GM batteries usually only last about 3 years
    Sep 2004
    53
    yeah i replaced the stock Delco battery with a good MTP Interstate. We tested for a drain and there definatly is a drain, was just trying to figure out if anyone else has heard of maybe a common place to start looking.
    99 SKALAID's Avatar
    99 SKALAID is offline Cadillac Owners Fanatic
    Feb 2004
    california
    37
    376
    there is a recall on the 1999 for the ON-Star draining the battery, check to make sure that this has been cleared up.
    Sep 2004
    53
    awesome im gonna check that out
    Marc Kessler is offline Cadillac Owners Member
    Apr 2004
    West Tennessee
    69
    23
    Every time I had to do something related to my On-Star account the battery on my 2000 died. Took it to the dealer, they replaced the battery then it happened a few months later. That's when I found out that On-Star was the culprit.
    r.knighter is offline Cadillac Owners Member
    Automobile(s): 1999 Escalade
    Jul 2012
    10
    I am having the same problem with my 1999. 99 SKALAID & MARC, did you end up having your Onstar disabled?
  11. Remove Advertisements
