sts starting problem
Results 1 to 2 of 2
Electrical Technical Information Discussion, sts starting problem in Item Specific Cadillac Discussion; i have a 94 sts that will not start sometimes, sometimes i move the shifter up and down and it ...
    mrgreazm0nkey is offline Cadillac Owners Member
    Automobile(s): sts
    Nov 2009
    46
    6
    i have a 94 sts that will not start sometimes, sometimes i move the shifter up and down and it will start so i replaced the safety neutral switch worked fine for a few days, i have noticed when it will not start the dash powers up like it should but when you hit the key nothing happens. sometimes it will start every time go to the store and come out it will not start waite about 10-15 minutes and it starts fine.
    lsteen is offline Cadillac Owners Member
    Automobile(s): 02 STS
    Sep 2010
    39
    Re: sts starting problem
    I had the same issue with my 02 STS, I got a new key made and now it starts every time, but I also turn the key on but don't try to start it until the security light goes out.
