Malfunction Indicator Light with P0741 and P1860 - Page 4
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 75
Like Tree7Likes
Electrical Technical Information Discussion, Malfunction Indicator Light with P0741 and P1860 in Item Specific Cadillac Discussion; cool...
  1. #46
    RippyPartsDept's Avatar
    RippyPartsDept is offline Hi, I'm Chris - Please Read My Signature
    Automobile(s): 1999 DeVille "Bianca" (white/blue, VIN-Y, 160k)
    Sep 2007
    Wilmington, NC
    34
    13,836
    Re: Malfunction Indicator Light with P0741 and P1860
    cool
    Chris Heath (RippyPartsDept) is an ASE Certified GM Parts Consultant at
    Rippy is a Cadillac, Hummer, Saturn & Saab dealership - family owned and operated in Wilmington, NC since 1946
    We offer all forum members deals on parts and freight - e: parts@rippyautomotive.com ph: 800-RIPPY-22
    <-- insert standard boilerplate about posts not necessarily representing my employer, etc -->
  2. #47
    OTTO's Avatar
    OTTO is offline Cadillac Owners Member
    Automobile(s): 2001 STS
    Dec 2009
    NW of Chicago, IL
    66
    I failed the emissions test!
    Learned about drive cycle the hard way.
    I'll drive her some more, be sure to do all the stuff listed and go back again.
    Is there a way to tell if the components that were not ready are ready before I go back?
    *Evaporative Control System
    *Heated Oxygen Sensor
    *Oxygen Sensor
  3. #48
    Submariner409's Avatar
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    74
    41,548
    Some of the emissions sensors need several successful (no fault/no excess emissions) start-run cycles to set the necessary ready flags in the OBD-II system. Either perform the complete drive cycle or drive the car normally for a week of commuting, with its starts and stops.
    Any way to tell ??? some aftermarket scanners will show a "ready" message when all is right, and so will a ScanGauge-II - www.scangauge.com
  4. #49
    Sep 2007
    Wilmington, NC
    34
    13,836
    some obd tools will tell you the readiness
    like this one apparently
    http://www.amazon.com/Autel-MaxiScan...dp/B001LHVOVK/
    it seems to be one of the less expensive ones that will tell the readiness
  5. #50
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    The Caddy is my weekend car. I have a service truck supplied and gassed by the company I work for that I bring home.
    I'll do the Drive Cycle for a few weekends then go to Autozone and see if their scanner can tell me I'm ready.
    I was wondering if there's a way to run or read the codes without using a scanner to see if the flags are gone and the sensors are ready.
    As always, thanks for the help.
  6. #51
    Feb 2006
    74
    41,548
    Our system won't tell you emissions systems status - but if there are no Current P codes then the system should be ready for test - BUT several emissions codes (some P codes) need several "clean" start-run cycles to set the ready flags, and I don't know how many successful start-runs it takes to get rid of the H designation for emissions.
    Did you look at the ScanGauge ?? It's a handy piece of engine monitoring and diagnostic tool .............
  7. #52
    Sep 2007
    Wilmington, NC
    34
    13,836
    i forgot about the ScanGuage II ... it does readiness as well, right?
  8. #53
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    I don't really do enough automotive work to justify the purchase of a scanner. Also we're saving for a down payment on a new house so funds are tight.
  9. #54
    Feb 2006
    74
    41,548
    Chris, Yep, it has 5 buttons on the face - when in the "4 gauge readout" mode you can use one button to scroll to the scan/codes/ready/not ready screen - on the fly.
    The unit is not simply a scanner - it constantly monitors 12 engine, transmission, and car functions and you can set it to readout any 4 at one time. I set mine to: Intake Air Temp, Coolant Temp, Ignition Advance and MAP (Manifold Absolute Pressure = vacuum = load). It is also a comprehensive trip/fuel/cost calculator.
    If you are a button pusher you can program in an additional 4 or 6 gauges, depending on what your OBD or CAN system monitors.
  10. #55
    Sep 2007
    Wilmington, NC
    34
    13,836
    does it have a cable so you can mount it anywhere?
    i would assume yes, right?
  11. #56
    Feb 2006
    74
    41,548
    Yep, it comes with a 6 foot cable - OBD connector on one end, ethernet click-in connector on the other.......... and the new SG-II models can be daisy-chained together for a constant 8 gauge digital readout. Stick-on Velcro strips also supplied.
  12. #57
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    There's an auto shop nearby that will scan the Caddy let me know if she is emission test ready (no charge).
    So I'm off to Rockford & back this morning with stops here & there to complete the drive cycle.
    Just for the fun of it, I'm going to try this cheap scanner out. Comes with software and will link to my laptop via bluetooth.
    Super Mini ELM327 v1.5 OBD2 OBDII Bluetooth Adapter Auto Scanner Android
    $12.40 with free shipping, what's the worst that could happen?
    I'll let you know how the test goes and how the scanner works.
    Probably should start a new thread and not add more to this old one.
  13. #58
    Sep 2007
    Wilmington, NC
    34
    13,836
    as long as you're not planning on using the ELM with an apple device
    it work with torque app (which is android only)
    and it also has a cd to install software on a laptop, palm, or windows phone
    but torque is probably the best
  14. #59
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    Yaaaay! I passed the emissions test! I feel so much better now, I can once again look down on the Prius-driving people with a smugness thet thought belonged only to them.
    The ELM will be bluetooth connected to my Panasonic Toughbook CF-30.
    No wimpy tablet or smartphone for me.
  15. #60
    Sep 2007
    Wilmington, NC
    34
    13,836
    ok cool
    OTTO and OTTO like this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
