1997 deville with headlight problems.
Results 1 to 6 of 6
Electrical Technical Information Discussion, 1997 deville with headlight problems. in Item Specific Cadillac Discussion; I own a 1997 cadillac deville, the other day I went out to my car and noticed that the headlights ...
    bman508 is offline Cadillac Owners Member
    Jul 2003
    Massachusetts
    48
    6
    car and noticed that the headlights were on. This is odd since
    the car has automatic headlights (the headlight knob was still
    in the off position). I had to have the car jump started and
    thought that the problem must be that the light sensor for the
    auto headlights was faulty or dirty. Alas once the caddy was
    jump started I was unable to turn off the headlights! I
    discovered that one of the relays (the low beam) was smoking. I
    removed the relay and the headlights went out. I removed the
    relay for the horn (which is the exact same part number as the
    one that was burnt) and put it into the headlamp slot and the
    lights did not work. I purchased a new relay and that didn't
    work as well, but if I put the burnt one back in the lights come
    on and the relay starts to smoke. The only other symptom I can
    see is that the highbeams will come on but will not stay on
    unless I hold the directional in place. What could be the
    problem??? Also I have replaced the headlight switch and the problem still exists.
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    Re: 1997 deville with headlight problems.
    Quote Originally Posted by bman508
    First of all, there's (3) relays for your headlamps;
    One Headlamp relay (relay 'A')
    One High/Low Beam control relay (relay 'C')
    One Daytime running lamp relay (relay 'F')
    So first, we have to figure out what relay is smoking.
    Let me know.
    Jul 2003
    Massachusetts
    48
    6
    Quote Originally Posted by Katshot
    Let me know.
    I don't know which relay it was. It is located in the maxi fuses/ relay center located on the engine compartment fuse block on the drivers sinde of the engine block. If you look at the diagram in the owners manual (p. 6-60) it was the relay located just a little right of center (on the diagram) labeled HEAD LPS.
    My lights are now working although the headlights only turn on when the twilight sentinel is activated. If I pull on the knob the driving lights illuminate but not the head lights.
    klute is offline Cadillac Owners Member
    Nov 2003
    4
    Did you ever fix your problem with the headlights?
    hazelshome is offline Cadillac Owners Member
    Automobile(s): 99 STS 2005 SRX
    Nov 2003
    homer glen il.
    76
    6
    go to headlights wont turn on thread
    check my answer who knows it might work
    dna_level_c7 is offline Cadillac Owners Member
    Automobile(s): 1997 Sedan Deville
    Nov 2011
    32
    8
    I know this thread is a little old but I just bought a 97 Deville yesterday with the same problem.
    Taillights and park lights worked fine but no headlights or highbeams, just DRLs when the car is in gear.
    I have been up all night searching the forums and located the headlight relay on the driver's side under the hood. I pulled it out and swapped it with the horn relay and and there wasn't any problem with the relay. The socket was corroded so I cleaned it with some contact cleaner, pushing the relay in and out and voila! I now have headlights!
    This seems like a great forum and I am glad I came across it!
  9. Remove Advertisements
