Power windows 97 SLS...Please Help
Results 1 to 4 of 4
Electrical Technical Information Discussion, Power windows 97 SLS...Please Help in Item Specific Cadillac Discussion; Can someone help me??? None of my windows are working at all. I checked the circuit breaker under the hood ...
    jincognito is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Sls
    Feb 2010
    38
    1
    Can someone help me??? None of my windows are working at all. I checked the circuit breaker under the hood and it seems to be fine. Does anyone have another suggestion of what i should check. i pulled the door panel off and have access to the main switch but am not sure how to test it.
    Eric is offline Cadillac Owners Fanatic
    Automobile(s): 2000 SLS
    Aug 2003
    SoCalif
    292
    Re: Power windows 97 SLS...Please Help
    Post more on anything you have done - anything - and maybe someone will be able to help you. You can find a lot of problems with an independent power supply and ground.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    You test it with a test light. With car running put the alligator clip on a good clean ground and the probe on the back side of the switch. The large purple or pink wire should be hot at all times, car running. It should light up the bulb in the test light handle. Then one at a time, probe each wire to each switch. As you move the window switch, one side should light up, then moving the switch the other direction the other wire to that switch should light up. If you have no power to the purple or pink wire then suspect a broken wire between the door and door hinge area. Opening/closing the door over the years can break wires within the plastic boot the wires run thru.
    eyeu81 Guest
    My 1998 SLS had the same problem, could not find any wiring problems in doors or switches. Took back seat out to access the computer boxes behind them and disconnected and reconnected all the wire connectors and all but the passenger front switch work now. I can work passenger front with driver side however. So something was loose, not sure what it was but none worked before this.
  7. Remove Advertisements
