Navi Screen won't come on.
Results 1 to 5 of 5
Electrical Technical Information Discussion, Navi Screen won't come on. in Item Specific Cadillac Discussion; Yesterday my car battery died on me due to me not turning my car on... Anyways when I did get ...
    DaLadizMan is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Deville DTS
    Sep 2008
    Greenboro
    29
    4
    Yesterday my car battery died on me due to me not turning my car on... Anyways when I did get the car to start after receiving a jump my screen stays blank.(black) Anyone know what the problem could be? I checked to see if it could be a fuse considering it worked yesterday. I couldn't find a fuse for it though.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Re: Navi Screen won't come on.
    Unhook the battery.
    It is common on Deville for this to happen if the battery goes down and is charged.
    It is "logic locked" (computer stupid) and it just needs a power reset.
    It won't take much time disconnected, then it will likely work fine when you hook it back up and turn the key on.
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    I wonder if the Original Poster solved his problem.
    I had a similar problem (but without having a dead battery). Nav was dead. I pulled the rear seat, located the fuse for the NAV, removed and reinserted fuse and all was good.
    bhopt2003 is offline Cadillac Owners Member
    Automobile(s): escalade
    Jan 2011
    17
    what was the name of that fuse you pulled please!!
    edilagan is offline Cadillac Owners Member
    Automobile(s): Deville 99
    Mar 2010
    57
    6
    I have the same problem, but mine is only the center part of the cluster that has no display - the fuel consumption part on the left has it, and the AC info on the right has it, too. I located the fuse, it is named "CLUSTER", 20 A. I pulled it out, cleaned the contacts and put it back in. No effect. As dead as before. While the car engine is running, I pulled out the fuse. Everything on the screen went blank. When I put it back, there comes the display again for the fuel and AC. So mine could have a different problem. Any ideas? Thanks a lot. Deville 99.
  8. Remove Advertisements
