| Infamous u 1300 So I've had several issues in the last month with my 98 concours. Last year I did the water pump crossover gaskets. While in there I guess I didnt tighten down the main pcm ground which in return damaged the pcm. Got that figured out after "no pcm data" on the DIC, 2 pcms and still the same problem. Shop found the ground and all is well with the pcm. I changed the hearter core earlier in the month had to remove the ACM to get the heater core out. Now Im having the same issue with RSS computer as I did with the PCM. The RSS module is cycling air ride compressor on and off...go to pull codes and I have serveral modules with U1300 codes, when its time to read the codes to for RSS module it says no "RSS data" However I do get data with the key in just the on position motor not running. The climate control goes wacky and the fuel gauge drops to empty. I did have to replace the key pellet reader in the ignition because of broken wires. Anything would help me out greatly here. I have a guy at my shop that really wants to fix this problem! |
