Had this issue a couple years ago, display said "DOOR OPEN" when shifter moved out of park. Ended up being the passenger back door latch switch. All I did was disconnect it. The "DOOR OPEN" Message popped up again this week. Trying to track down which latch was bad, I have pulled ALL door panels including drivers and disconnected wiring to the latch. Start car, move shifter from park, and there it is again, "DOOR OPEN"
. How would the DOOR OPEN message still come on if all wiring was disconnected? I wouldn't care so much if it was just the message, but there is an annoying chime that rings when you pull away from a stop. At this point I wouldn't even mind just cutting the wire to the BCM that would indicate the door ajar, if anyone knew where it was and which to cut. Is there any other type switch in the door? Seems like there is since the dome lights don't stay on and neither does the security light. HELP
