A/C Clutch Coil Resistance
Results 1 to 2 of 2
Electrical Technical Information Discussion, A/C Clutch Coil Resistance in Item Specific Cadillac Discussion; For 1993 Sedan Deville 4.9L: Does anyone know the nominal spec for the A/C clutch coil resistance? I'm reading 1.2 ...
    pderk is offline Cadillac Owners Member
    3
    I'm reading 1.2 ohm which seems rather low.
    Any info is greatly appreciated.
    Thanks
    Paul
    Sep 2003
    Metro ATL
    4,854
    Re: A/C Clutch Coil Resistance
    Don't have your specific clutch coil here but the one's I have measured from "modern" vehicles have been in the 1 to 2 ohm range. A strong magnetic field is required to "pull-in" and grab that drive pulley.
    Once the clutch is engaged, the resistance is increased to produce a "hold-in" level of magnetic field strength.
    Sounds like your's is in the normal range to me.
