94 Blower Motor
Results 1 to 3 of 3
Electrical Technical Information Discussion, 94 Blower Motor in Item Specific Cadillac Discussion; Hello all, Does anyone know where I can find the schematics for a 1994 STS blower motor??...
    time4funn is offline Cadillac Owners Member
    Jul 2004
    94 Blower Motor
    Hello all,
    Robteesit is offline Cadillac Owners Member
    Jul 2004
    Virginia
    11
    Re: 94 Blower Motor
    Don't know if yours is like mine,(see post on 96 sts blower install?) but I found a test tech tip for the blower motor earlier in this forum. I think on the 8th page. Basily to test - Terminal C power supply should read battery voltage. Terminal A - is a ground and Termial B is varying voltage from less than 4 volts ( when switch is on high) to 11 to 12 volts when switch is off. Don't know if this helped. You could ask my question on how to reinstall the blower motor into the housing with out breaking it could you?
    Jul 2004
    Re: 94 Blower Motor
    Quote Originally Posted by Robteesit
    Thanks for the reply Robteesit, but I'm looking for the schematics for the blower motor. I have two of them that are dead. I would like to repair them if I can.
