94 Deville Starting problems
Results 1 to 2 of 2
Electrical Technical Information Discussion, 94 Deville Starting problems in Item Specific Cadillac Discussion; Hello all, I recently purchased a low mileage 94 Deville...i really like the car but it has developed a strange ...
    bigcountryfx is offline Cadillac Owners Member
    Jul 2004
    5
    Hello all,
    I recently purchased a low mileage 94 Deville...i really like the car but it has developed a strange problem; after driving for a while then turning off the car....trying to start it immediately again is a real pain. It turns over like the battery is dead...i even went and bought a brand new battery with the most cranking amps i could fit in there (1000). I would have thought that would have fixed it but it doesnt. After a while, the car will start again...but that is a bit of a pain if i just wanna run to the store quickly. Has anyone else experienced this type of problem?...the lights and radio and all other electrical items work perfectly...(except for the turn signal...but i can find the signal flasher; hazard flasher yes, signal, no)..any responses would be greatly appreciated.
    biggs is offline Cadillac Owners Member
    10
    Re: 94 Deville Starting problems
    i have 1995 deville with the same problem i have change the battery, tune-up alternator and was going to replace the starter today but why would the starter effect the signal lights so i did not change it stuck like you but also the signal lights work fine with the battery charged or just installed
