Door lock fuse keeps blowing
Results 1 to 3 of 3
Electrical Technical Information Discussion, Door lock fuse keeps blowing in Item Specific Cadillac Discussion; My fuse blows instantly (#15) when I put it in. My car is a 1990 Cadillac DeVille. The fuse runs ...
    green570 is offline Cadillac Owners Member
    Jul 2004
    1
    My fuse blows instantly (#15) when I put it in. My car is a 1990 Cadillac DeVille. The fuse runs the door locks and the dome light. Also, The air pump for the self-leveling system comes on quite frequently. Our air-conditioner blows hot air. Can you suggest where to start? I have pulled all the door panels to see if there was a wire shorting on the door locks but found nothing.
    barge master's Avatar
    barge master is offline Cadillac Owners Enthusiast
    Northern Ct.
    53
    624
    Re: Door lock fuse keeps blowing
    You might want to try taking the door lock system out of the loop by unplugging the relay power from the fuse panel. On the RWD cars it is a big orange wire with a black stripe. You may find it's not in the lock circuit at all. Also try tugging on wiring harnesses under the dash. Sometimes just wiggling wires reveals those problems.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    You might look at all the lighter sockets for tin foil or coins. Usually when that fuse blows its not the door locks at all, but lighters or sockets shorting. Good luck, Bill.
