96 SDV . Battery drains
Results 1 to 5 of 5
Electrical Technical Information Discussion, 96 SDV . Battery drains in Item Specific Cadillac Discussion; Battery was draining over the weekend and would have to jump off in the morning . Now it does it ...
    BooBoo77 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    12
    Battery was draining over the weekend and would have to jump off in the morning . Now it does it every day . What might be cuasing the electrical drain . I removed the horn relay and it didnt help . Been doing it since before I bought the car last year and has slowly gotton worse . Thanks . BooBoo77
    Dec 2007
    12
    Re: 96 SDV . Battery drains
    OK , I did a draw test with a test light and it stays on . So I started pulling fuses and the light stayed on until I pulled a Maxie fuse . Its the 3rd one down marked 50 amp "BODY" . So what should I do now ? What all does that fues control ? Thanks . BooBoo
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,179
    Either the BCM (Body Control Module) or the RAP (Retained Accessory Power) module. They control power to every light, switch, button, who-knows-what in the car. If one module hangs "ON" it will drain the battery in short order. Read up on how to pull your codes for diagnostics - its already built into the car - and see what's going on. Instructions are at the top of this, Northstar performance, Seville, Deville, and Cadillac Technical Tips main pages.
    Dec 2007
    12
    Thanks for the reply , I'll check it out .
    richscho is offline Cadillac Owners Member
    Automobile(s): 1997 Deville Concours
    Oct 2009
    12
    I agree that the problem is a BCM problem, but: Are you certain that "the battery is being drained?"
    I have a somewhat similar problem but I have over a very extended distress with this problem, come to the conclusion that the battery is not being drained at all. In fact, the battery "will not drain!"
    What started as an intermittent, and originally infrequent problem, has developed into a: "Turn it off, and it will not even think about restarting" problem. However, hook a 'jump box' up and it starts immediately, and without hesitation. (An effective, though moderately embarrassing normal mode of operation.)
    The car cannot find a ground until the jump box is attached. The jump box supplies a 'ground', and everything proceeds swimmingly.
    Now comes the next step in the quest: Which BCM is causing the problem? It appears that there are at least two modules designated as BCMs, and over time, I have heard murmurs (literally) from the locations of multiple such modules.
    In shopping for parts, I have found that some BCMs may also exist in the doors, but the locations from which I have heard sounds, are located: a) behind the right side of the rear seat; b) beneath the passenger side front seat; c) from the dash, behind the air bag area on the passenger side.
    How does one determine the location of a BCM problem? (Which BCM is the problem, and how do I know?) I am not amused at the prospect of replacing anything that is called a BCM just to surround the problem?
    If your battery is really being drained, by a BCM, then you may be able to determine which such module controls the function through which the 'drain' is flowing. Or at least that makes sense to me. If I have no flow (no "open" "drain" paths, how do I address this?
    I would act to determine what route your electrons are using to disappear, before they decide not to disappear at all...
  8. Remove Advertisements
