Originally Posted by hobo69  Ok I fixed it I checked out the light sockets and found one the bulb turned a little to much put a new light socket in and now it works right.Just thought I would share it with every one. |
Glad to hear it. I found the lights go goofy when a simple problem exists.
I found the light bulb base - contact tips will disfigure in time due to heat and create blinking woes.
I have been chasing my rear tail lights blinking weird, and finding the ground wire that plugs into each of the light socket needs to be "self-adjusted" in the inlet to work properly. I had to slide out the ground plug a tiny bit to correct the fast flashing. I used a tie wrap to secure it in this "new" position.
For the life of me, I could not figure out how to remove the ground and service the contact. You stick a tiny blade in to release but I couldn't figure out at what "clock position" to stick it in.
The only thing I have left to fix is my left turn light won't turn on, and I know it's not the bulb.
