Battery charging circuit question......
Results 1 to 4 of 4
Electrical Technical Information Discussion, Battery charging circuit question...... in Item Specific Cadillac Discussion; The alternator does not charge the battery on my 87 DeVille. The alternator is good. The battery charge warning light ...
    Fred Noonan is offline Cadillac Owners Member
    11
    QuestionBattery charging circuit question......
    The alternator does not charge the battery on my 87 DeVille. The alternator is good. The battery charge warning light is out.
    I believe the alternator field energizing current flows through the bulb when the ignition is turned on.
    Can anyone tell me if there is a resistor in parallel with the bulb to allow the current to pass when the bulb is burned out? If so, what is the value and watt rating of the resistor and where is it located?
    Thanks.
    barge master's Avatar
    barge master is offline Cadillac Owners Enthusiast
    Northern Ct.
    53
    624
    Re: Battery charging circuit question......
    The current drawn through the bulb is what excites the field in the alternator, if the bulb is burned out, it won't begin charging. Also,make sure you have power at the stud on the back of the alternator.
    brad3378's Avatar
    brad3378 is offline Cadillac Owners Member
    Mar 2004
    Dearborn, Michigan
    45
    I have a similar situation with my 98 Deville
    (Battery & Alternator tested good at the autoparts store)
    My next step is to test the circuit for the regulator.
    My Chilton Manual shows two wires coming off of it.
    One goes to the PCM and the other goes to the Electronic Instrument Panel Cluster.
    My question is this:
    What kind of signals should I be expecting at the regulator harness connector? I am assuming that the instrument panel supplies Positive voltage to the circuit and the PCM supplies the field circuit ground. Am I correct?
  5. #4
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,423
    The only thing the bulb is there for is to tell you when there's a problem.
    Bring it in somewhere to get the charging system checked. That'll tell you what's wrong.
  6. Remove Advertisements
