engine ground
Results 1 to 5 of 5
Electrical Technical Information Discussion, engine ground in Item Specific Cadillac Discussion; I have a 94 sedan deville with a 4.9. Im adding stereo equipment to it , and I can't locate ...
    ekropp is offline Cadillac Owners Member
    Mar 2004
    3
    engine ground
    I have a 94 sedan deville with a 4.9. Im adding stereo equipment to it , and I can't locate to engine to chassis ground.
    caddyshack24's Avatar
    caddyshack24 is offline Cadillac Owners Enthusiast
    Mar 2004
    Florida
    36
    599
    Re: engine ground
    an engine to ground should be somewhere near the battery or in the trunk..
    this is for an amplifier, if so.. you could sand a spot in the trunk and use that, shorter the ground, the better.. should also use the same gauge wire as your amplifiers power cable.. keep the fuse within a foot or three of the battery.
    mount your amplifer as per the manual, for heat disipation
    Mar 2004
    3
    Re: engine ground
    what im trying to do is called the big three. You upgrade your battery to chassis ground, the alternator to battery power, and engine to chassis ground. is supposed to help with light dimming with a powerful audio system. Ive done the first two I just cant find the engine to chassis ground.
    Mar 2004
    Florida
    36
    599
    Re: engine ground
    ok, makes more since it that context, not sure it thats true or not..
    I think this post might help a little.
    http://caddyinfo.ipbhost.com/index.p...opic=2113&st=0
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: engine ground
    Why not add the larger engine/chassis ground while retaining the factory one? Could only help having both there....
  8. Remove Advertisements
