blower gone?
Results 1 to 5 of 5
Electrical Technical Information Discussion, blower gone? in Item Specific Cadillac Discussion; this morning I noticed a elec burning smell pulled over noticed nothing burning, when I went ot work I noticed ...
    boldii's Avatar
    boldii is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac Eldorado cp
    Nov 2008
    on a Yacht in Long Beach Ca
    62
    blower gone?
    when I went ot work I noticed that the blower was not working for heat or air some say that if you smelled burn it eas more than likley the blower and not the relay how do I find out? we are talking of the elec blower for the air and heat
    Dlewis is offline Cadillac Owners Member
    Feb 2012
    5
    What year and model? I have a 99 Deville. My blower motor has went out twice now. The motor and resistor are all in one. New is up to $200. Used from a salvage yard will vary as well if you can put it in your self. I have found tons of info from everyone in the forum. Just look around and read.
    vitovent's Avatar
    vitovent is offline Cadillac Owners Member
    Automobile(s): 1999 Deville D'Elegance
    Jul 2011
    Arkansas
    41
    39
    I just replaced mine for the first time last week. Check this link, I love my New blower, working great for now:
    http://www.amazon.com/gp/aw/d/B002E5...sr=8-1&pi=SL75
    Feb 2003
    california
    69
    6,680
    Re: blower gone?
    Run a jumper wire from the positive battery post to the power wire on the blower motor. does it turn on? If not, replace the motor.
    vitovent's Avatar
    Jul 2011
    Arkansas
    41
    39
    Check this link:
    http://www.cadillacforums.com/forums...ml#post3161935
    Discussion includes similar problem, including voltage checks on existing blower. You will need a volt meter. DO NOT CHECK CONTROL WIRE TO RED (HOT) WIRE, this will send 12+ volts thru control wire, possibly, most likly, frying your blower.
    Do check red to ground, even with ignition off, key removed, you should have battery voltage (12+ volts DC) on red wire.
    Check wires with plug attached to blower by running the leads thru the back side of the plug, just follow the wires into the plug. Don't worry, its a rubber moisture shield you will be poking thru.
    Put red lead on middle wire (control wire) and black lead either on black wire, or engine ground somewhere, or even the negative car battery terminal.
    Run the blower modes thru their paces. Set "hi" and "lo" , checking voltage at control wire.
    As the link describes, you should see a voltage change at the control wire.
    See Rangers posts on the subject as well, he was a big help when I was troubleshooting.
    I, ultimately, had to replace the blower motor, which on my 99, was on the firewall under the hood. I'm no mechanic, and it wasn't too difficult a job. Lots of steps, and you will need lots of patience.
    Use this site to do your homework first! I can't stress that enough. I spent a few days reading threads on the subject. There is plenty of help and helpful people here!
  8. Remove Advertisements
