95 Deville Lights out
Results 1 to 3 of 3
Electrical Technical Information Discussion, 95 Deville Lights out in Item Specific Cadillac Discussion; My 95 Deville started the quick blink when I turned on the left turn signal. I saw that the top ...
    buyusa is offline Cadillac Owners Member
    My 95 Deville started the quick blink when I turned on the left turn signal. I saw that the top light in the back tail light was not lighting up. When I went to replace the bulb I noticed that the bulb looks good. I replaced the bulb anyway and the speed of the blink returned to normal. The next day I was driving at night and noticed that I did not have left rear taillights or left front turn signal lights on however they came on when I engaged the left turn signal. I read the thread of checking for brown socket and the socket did not look burned on the 2 bulbs in the back taillights. Now when I apply the brakes the green lighton on the headlight switch comes on and the left front turn signals light up. The brake and turn signals work fine however the dash lights blink with in time with the left turn signal. Any ideas welcomed.
    buyusa
    wikid65's Avatar
    wikid65 is offline Cadillac Owners Member
    May 2004
    41
    Re: 95 Deville Lights out
    Replace the suspect socket. Those year Devilles were notorious for losing the ground in the socket and/or melting the solder on the bulb base.
    Thank you I will try that...Wow 42.95 at my local pit stop..Thanks again.
    buyusa
