Horn Problems
Results 1 to 8 of 8
Electrical Technical Information Discussion, Horn Problems in Item Specific Cadillac Discussion; I have a 1969 Caddy Hearse Fleetwood model. I can't get the horn to work. I have used a hot ...
    Sasquatch's Avatar
    Sasquatch is offline Cadillac Owners Fanatic
    Mar 2004
    Bluff Creek
    322
    Horn Problems
    I have a 1969 Caddy Hearse Fleetwood model. I can't get the horn to work. I have used a hot wire to the horns themselves and they are both good. In trying to read the schematic in my shop manual I believe there is some kind of horn relay under the dash. Can someone explain to me how the steering wheel mechanism for activating the horn works. I've had the rubber cover off and there is a white wire attached to a plastic "button" that I assume when depressed should activate the horn. Haven't put alot of time into this problem yet so I thought I would post here for suggestions. I have checked the fuse and it is good. Thanks.
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Horn Problems
    Does your key reminder buzzer work? (Work is a relative term, I had to push my key in to get it to buzz, but it did buzz...)
    Reason is that the Horn relay and the key buzzer are usually the same unit.
    Sasquatch's Avatar
    Mar 2004
    Bluff Creek
    322
    Re: Horn Problems
    Dave, Just tried the key and no buzzer. Where is that relay located? Thanks.
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Horn Problems
    Its a silver can with one large connector on one side, and a small one wire connector on the other. On my car, it is located under the instrument panel, to the left of the steering column on the firewall.
    Sasquatch's Avatar
    Mar 2004
    Bluff Creek
    322
    Re: Horn Problems
    Dave thanks for the reply. I had already located it and replaced it and still no horn. I've included some pictures below. On the relay the single spade connector on the left has a white wire that I've traced continuity to the horn feeds that hook to the horns themselves under hood. Got good continuity in both so that is good. Moving right the next single spade connector is part of the bigger three wire connector and it has a red wire going to it. The upper right spade has a black and white wire and the lower right spade has a green wire that I traced continuity to the brass colored metal inside the steering wheel under the cover. The white wire with the round connector inside the steering wheel, at the bottom, I'm assuming is the one when touched to the wheel completes the circuit and sends the power to the right side of the relay which then activates it and sends power to the horns via the single spade connector on the left of the relay. I cannot seem to get anything from the white wire in the steering wheel to the right side of the relay. How does this work. Does this relay have to be hard mounted to the firewall so that it it is grounded? The old one had some sort of bracket that just hooked into the old floorboard insulation. It was not mounted to the firewall. Pulled the bottom of the dash and can't trace where that white wire goes or how it ties into the relay. Thanks for any help. Electrical is always tough but this one can't be to hard.
    Sasquatch's Avatar
    Mar 2004
    Bluff Creek
    322
    Re: Horn Problems
    Got it fixed. There is a flip open access at the bottom of the steering wheel. Opened it and one of the solder joints came loose. Resoldered and all is well. Thanks.
    garck is offline Cadillac Owners Member
    Nov 2003
    38
    52
    Re: Horn Problems
    Tbanks, You may have just solved the horn problem on my 69 Coupe Deville the guy at the shop said that the wire connection at the bottom of the steer wheel was bad I haven't had time to troubleshoot it. thanks
    Sasquatch's Avatar
    Mar 2004
    Bluff Creek
    322
    Re: Horn Problems
    Also remember to activate this horn you must press in on the OUTER ring of the steering wheel. Not the center pad. On mine there are a couple of dead spots that won't sound the horn. I found at the top of the wheel if I take my thumb and press in on the OUTER ring I can sound the horn every time. Hope this helps as well. Happy honking.
  11. Remove Advertisements
