| Qs about Secondary Fuse Box Hey all... I have a few modifications I'd like to do to the car, and wire everything into a switch panel. These switches would control, among other things, interior neon lighting, exterior neon lighting, (aftermarket) fog lights, CCFL "angel eyes", so on and forth.
I plan on running two wire into the switch panel - a constant 12V source and a switched "ignition" 12V source. Would I be OK using a distribition block for amp power wires?
My other question is, instead of wiring a seperate fuse link into each switch's wire, could I consolidate it into a "mini" fuse box? Do they sell those things aftermarket with room for maybe 10 or less fuses? I want something easy to get to and convenient to change the fuses. Thanks for any help you can give me! |
