Drivers side low beam headlight not working right.
Results 1 to 3 of 3
Electrical Technical Information Discussion, Drivers side low beam headlight not working right. in Item Specific Cadillac Discussion; On my '84 DeVille the other day when I was going to work I went to turn on my headlights ...
    rollerz70 is offline Cadillac Owners Fanatic
    May 2004
    105
    On my '84 DeVille the other day when I was going to work I went to turn on my headlights and noticed that only the passenger side on came on. But when I turn on my high beams then the low beam will come on. What could make this happen?
    brianroark's Avatar
    brianroark is offline Cadillac Owners Fanatic
    Automobile(s): 98 Devil, 93 Deville, 84 Cuttylac built 350 olds, Arctic Cat
    Nov 2003
    Milwaukee, WI
    35
    181
    Re: Drivers side low beam headlight not working right.
    replace the bulb. with that car your lowbeam is burned out but high beams will still function i believe that those are not halogen and a light bulb its self. replace the light it is fairly inexpensive...
    May 2004
    105
    Yep it was just the low beam out. Changed it today and now I'm back in business!
