1996 Seville SLS, Duel Zone A/C - cold/hot
Results 1 to 6 of 6
Electrical Technical Information Discussion, 1996 Seville SLS, Duel Zone A/C - cold/hot in Item Specific Cadillac Discussion; Hi Guys! I hope that someone can help. With A/c on, drivers side vents (and rear seat), blow cold, the ...
    bolvey.1's Avatar
    bolvey.1 is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Apr 2004
    Syracuse NY
    31
    Hi Guys!
    With A/c on, drivers side vents (and rear seat), blow cold, the passenger side vents blow HOT.
    I pulled the passenger under dash pannel off and looked for anything obvious.
    I cycled the system from A/C to heat and rotated vent positions to check for vent door movements and to indicate a vacuum leak.
    All seems to check out OK.
    What controls the duel zone system?
    Can anyone help?
    PS the car sat for 2 years. I bought it in April from the estate of an elderly women with 36000 miles on it.
    Low refrigerant light was on, Compressor would not run. I added 2 lbs of refrigerant (via gravity feed), disconnected the battery to clear the code, and the A/C compressor took off.
    Now, constant heat from passenger vents.
    I appreciate your help.
    Mark
    69
    82,266
    Re: 1996 Seville SLS, Duel Zone A/C - cold/hot
    I have the same (though intermitent) problem with my '97 Deville. I have not been able to find a cause but I have found a simple fix. I simply run the temp up to 90 then back down to 72 or whatever and it opperates normally from then on. Hope this helps.
    bolvey.1's Avatar
    Apr 2004
    Syracuse NY
    31
    Red faceRe: 1996 Seville SLS, Duel Zone A/C - cold/hot
    Thank you!
    I'll try it and let you know if it works for me.
    Mark
    bolvey.1's Avatar
    Apr 2004
    Syracuse NY
    31
    Hi Ranger,
    I tried your suggestion with no luck.
    Any other ideas?
    Thanks,
    Mark
    cruzajc1's Avatar
    cruzajc1 is offline Cadillac Owners Enthusiast
    Apr 2004
    500
    Either a short or the Temparture Door Actuator Motor under the glove box needs to be replaced. Your lucky, if it was the driver side, it would be big $$$ Hope this helps.
    Gus
    cruzajc1@aol.com
    bolvey.1's Avatar
    Apr 2004
    Syracuse NY
    31
    I broke down and took it to the dealer.
    Temp door Actuator and the compressor was bad.
    Thank God for extended warranties!
    $1500 for ice cold air!
    Mark
  9. Remove Advertisements
