| Re: Intermittent code means? Without going into painful detail....
The TCC is applied by a solenoid blocking a fluid passage (basically) routing fluid behind a clutch disk in the converter. The disk locks the two halves of the converter together mechanically to eliminate the characteristic torque loss from a fluid coupling of an "old school" converter.
(more efficient)
What causes the code to set is when there is a leak in the hydraulic circuit or a mechanical failure of the converter itself.
You could have a failing solenoid, leaking seals, gaskets, or worn hard parts causing the code to set.
An experienced tech will know what to replace to cover all the bases, yes it is an expensive and time consuming repair as the trans needs to come partially apart... and it aint held in by velcro.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
