anyone with a wiring diagram for the trans? I recently had the trans replaced, now i get abs light, t/c light, and parking brake light!!! sometimes they go on and off, i might hit a bump and it goes off or come on. i also have a harsh shift after i drive the car for a little. when they replaced my trans the first time they put the incorrect trans in the car. They replaced again, caddy dealer says its correct, but i still have shifting problem. i still get a incorrect gear ratio code from the last trans. i cleared the codes and it came back. Is it possible that i have to clear the codes with a tech 2 scanner inorder to get rid of it out the PCM???
