| Electrical Technical Information Section for discussions in regards to electrical systems. | Cadillac Forums: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash
06-27-08, 02:30 PM
| | Cadillac Owners Member Cadillac(s): 1997 Cadillac Seville SLS | | | | | 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash About six months ago I noticed that my turn signals were making a weird sound. It sounds loose, or "laggy" but didn't seem to effect the turn signal itself, so I temporarily ignored.
Now about a week ago, the turn signal still makes the same sounds, but now it will stop blinking every so often, a few times a day. And I will either have to manually work the signal or fuss with it until it goes back on.
Can anyone please help me with what I need to be looking at?
Thanks in advance! |
06-29-08, 03:15 AM
| | Cadillac Owners Member Cadillac(s): 1997 Cadillac Seville SLS | | | | | Re: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash come on, hasn't this happened to anyone before? =/ |
06-30-08, 06:03 PM
| | Cadillac Owners Member Cadillac(s): 1997 Cadillac Seville SLS | | | | | Re: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash please help me bump |
07-01-08, 03:45 PM
| | Cadillac Owners Fanatic Cadillac(s): 1993 Eldo 4.9 66K miles | | Join Date: Nov 2005 Location: Nazi Jerky, libtard central | | | Re: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash Best guess would be the flasher unit itself up under the dash on the driver's side, I believe. |
08-05-08, 10:06 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash I came across this post today when I started researching the problem. I have a '95 SLS with the same symptoms.
Boiled down to replacing the turn signal relay for $15 from my local parts store. But, the thing is not easy to find. You have to remove the plastic insulation panel under the dash & above the pedals. Then, dig around for the flasher clipped to the dash shelf to the left of the steering column. The hazard flasher is a round unit and easy to see. The turn signal flasher is rectangular and hidden. As a note, the section in the Cadillac shop manual pictures these as the reverse of that.
Good luck. |
09-09-08, 03:19 AM
|  | Cadillac Owners Member Cadillac(s): 1995 Eldorado | | Join Date: Aug 2007 Location: Tucson, AZ Age: 30 | | | Re: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash Would this be the same location of the turn signal relay for a 95 Edorado? My turn signals are also intermittent and gettting worse. There is a bank of relays in the trunk, back-side of rear seats, which has a turn flasher relay but the AC Delco part I purchased is twice as large as these relays and does not fit. So, I thought the parts store gave me the wrong part but, after reading your post I figured there must be 2 turn flasher relays...? One in the trunk & one under the dash as you described.
The new part I have has a metal clip on one side and sounds like what you described above. Pulled the insulation panel today but could not find this other turn flasher relay.
As I am laying under the dash *top of head pushes brake pedal* it should be to my left as I look up? Which is towards the passenger side.....I would completely adore any help! |
09-19-08, 07:28 PM
| | Cadillac Owners Member Cadillac(s): 1997 Cadillac Seville SLS | | | | | Re: 97 SLS Turn Signal Sounds "Loose" and intermittently stops flashing light&on dash it did end up being the turn signal flasher "module", took my mechanic 3 minutes to do the job. $14 part (shop discount)
fyi it is in fact under the insulation panel on the drivers side below the dash and above the pedals | | Cadillac Discussion Tools | | |
Censor is ON | | | |
