right turn signal
Results 1 to 4 of 4
Electrical Technical Information Discussion, right turn signal in Item Specific Cadillac Discussion; right turn signal won't work but four way's work. i'm wonderin if it is a problem in the colem or ...
    redneck488 is offline Cadillac Owners Member
    May 2004
    Unhappyright turn signal
    right turn signal won't work but four way's work. i'm wonderin if it is a problem in the colem or wirein. any help would be apperiated
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    Re: right turn signal
    The burnt sockets are certainly something to look for. Here is a good picture of one....
    http://images.andale.com/f2/115/106..._memory_081.jpg
    The brown burnt spot is the internal ground in the socket burning up.
    It can also be a bad electonic flasher unit...or a bad turn signal switch in the steering column. The lower brake light circuit goes thru the turn signal switch.
    Logan
    www.airbagcrash.com
    www.logandiagnostic.com
    May 2004
    thanx but the image didn't upload to my pc i will look to see if that is the problem thanx fur the help.
    rollman's Avatar
    rollman is offline Cadillac Owners Fanatic
    Automobile(s): STS
    May 2004
    Phila Pa
    174
    I'm having kinda the same problem . Only difference one out of the three bulbs are blinking. The middle bulb on the right rear light . The bulbs are all fine . They light up like nomal when the parking lights come on but if you use the turn signal only one bulb comes on. Its driving me crazy .
  7. Remove Advertisements
