Add Homelink to 2003 DeVille
Results 1 to 11 of 11
Electrical Technical Information Discussion, Add Homelink to 2003 DeVille in Item Specific Cadillac Discussion; I would like to add a Homelink option to my 2003 DeVille. Is there anything else I have to do ...
    lakenboat is offline Cadillac Owners Member
    Mar 2005
    1
    I would like to add a Homelink option to my 2003 DeVille. Is there anything else I have to do other than slide a unit into the slot? Will this power it up or will I need to do anything else to make it work? It has the top console lights with sunroof controls which I do not know how to realease to get inside. Thanks for any help.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: Add Homelink to 2003 DeVille
    yup
    buy and slip into slot
    Sisqosasha is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac DeVille
    Jan 2014
    8
    Anyone know where to buy this for this car?
    Thank you,
    Ray
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,633
    Junkyard - all parts and modules - or talk to Chris in parts at Rippy Cadillac over there >>>>>>
    Maybe www.car-part.com
    How did you find a 7 year old thread ? Deep search ..............
    Jan 2014
    8
    It was a deep search, but I really wanted to find out the answer so it was worth it.
    Thank you for replying to a really old thread,
    Ray
    Jan 2014
    8
    Re: 2003 Deville w/o Homelink. Can I add one?
    If I install a homelink and it does not work, how would I remove the homelink from my 2003 Cadillac DeVille?
    Thank you,
    Ray
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    This is an 8 year old thread...
    Are you asking how to remove the unit from the console once installed?
    Feb 2006
    56,633
    He posted another question similar to this in another dead thread.
    I merged your Homelink question from the other dead thread. Please keep similar questions \in the same thread and let one work for you instead of shotgunning posts in hope of more replies.
    Thanks for the consideration.
    Feb 2003
    california
    69
    6,680
    There are at least 3 homelink modules thru the years. The proper one must match your type of opener. Most in the last few years are "rolling code" types and require the amber l.e.d in the slip in homelink module. Most any newer GM owners manual will walk you thru the programming sequence. To remove it I used a thin butter knife slipped in under it to depress the tang that locks it into the slot.
    Brandon Meats's Avatar
    Brandon Meats is offline Cadillac Owners Member
    Automobile(s): 2000 Seville SLS, 2003 Deville Base
    May 2009
    Wausau, WI
    36
    86
    I'm trying to do the same. From shopping around on the internet, it seems as though the buttons seem to cover a wide range of years, so I figure the one from my 2000 Seville should work in my 2003 Deville. I popped the blank cap out of the Deville and saw a plug inside. I went in the garage to my dead Seville and tried getting the buttons out of there, but they wont pop out. I tried with one of those pocket sized flat screwdrivers but no luck, can't get it to release.
    Feb 2003
    california
    69
    6,680
    Screwdriver is too narrow. A butter knife worked for me. The "door" doesnt pop out, it simply folds up as you insert the opener.
  14. Remove Advertisements
