PCM Code P0410
Results 1 to 12 of 12
Electrical Technical Information Discussion, PCM Code P0410 in Item Specific Cadillac Discussion; I got this code. I know it is related to the smog pump (or whatever they call them now). My ...
    2002STSPa's Avatar
    2002STSPa is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac STS
    Mar 2007
    Pittsburgh, Pa
    29
    PCM Code P0410
    I got this code. I know it is related to the smog pump (or whatever they call them now). My question is that I got this code after going to a Valvoline instant oil change place (yeah I am lazy like that). They boys take out the air filter to show it to me. Could they have knocked somthing loose at that time. I would go look but the weather went to crap here (freezing rain/snow) and my garage is temporarily unusable. Is the secondary air induction unit located near the main air filter housing? Could have a wire been knocked loose by one of the boys?
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: PCM Code P0410
    yuh def not fun to go out now....
    i doubt they knocked anything at the air filter...
    Oct 2005
    15,987
    Re: PCM Code P0410
    here man
    ALL you need to know....
    DTC P0410
    Circuit Description
    The secondary air injection (AIR) pump used on this vehicle lower tail pipe emissions during start-up. The AIR system consists of the following items:
    The AIR pump
    The shut-off valves
    The vacuum control solenoid valve
    The system hoses/piping
    The AIR relay, fuses, and related wiring
    The powertrain control module (PCM) uses the AIR relay to control the AIR pump. The PCM also controls the AIR vacuum control solenoid valve that supplies vacuum to the AIR shut-off valves. With the AIR system inactive, the AIR shut-off valves prevent air flow in either direction. With the AIR system active, the PCM applies ground to the AIR relay, and the vacuum control solenoid valve. Fresh air flows from the pump, through the system hoses, past the shut-off valves, and into the exhaust stream. The air helps the catalyst quickly reach normal working temperature, thus lowering the tail pipe emissions on a start-up. The PCM tests the AIR system for the following conditions:
    AIR system, overall system including both banks, and results in DTC P0410
    AIR system bank 1 (DTC P1415)
    AIR system bank 2 (DTC P1416)
    AIR relay (DTC P0418)
    AIR vacuum control solenoid (DTC P0412)
    The PCM runs two tests to diagnose the AIR system: Passive, and Active. Both tests involve a response from the fuel control heated oxygen sensors (HO2S) bank 1 sensor 1 and HO2S bank 2 sensor 2. If both passive tests pass, the PCM takes no further action. If either part of the passive test fails, or is inconclusive, the PCM initiates the Active tests. If the PCM determines that the HO2S voltages did not respond as expected during the tests, DTC P0410. For further information concerning the AIR system and system tests, refer to Secondary Air Injection (AIR) System Description .
    Conditions for Running the DTC
    Passive Tests
    DTCs P0102, P0103 P0106, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0121, P0122, P0123, P0131, P0132, P0133, P0134, P0135, P0137, P0138, P0140, P0141, P0151, P0152, P0153, P0154, P0155, P0157, P0158, P0161, P0200, P0300, P0335, P0336, P0351, P0352, P0353, P0354, P0355, P0356, P0357, P0358, P0506, P0507, P1133, P1134, P1138, or P1171 are not set.
    The engine is running for more than 2 seconds.
    The engine speed is more than 1000 RPM.
    The throttle is steady.
    The engine load is less than 80 percent .
    The system voltage is more than 10.5 volts.
    The mass air flow (MAF) is less than 35 g/s.
    The air fuel ratio is more than 11.1:1
    The engine coolant temperature (ECT) is between 5-110°C (41-230°F).
    The intake air temperature (IAT) is between 5-72.5°C (41-162.5°F).
    The power enrichment, or deceleration fuel cut-off (DFCO) not active.
    The start up engine coolant temperature (ECT) is between 5-80°C (41-176°F).
    Active Tests
    The engine is running.
    The mass air flow (MAF) is less than 75 g/s.
    The fuel system is in Closed Loop operation.
    The evaporative emission (EVAP) purge is active.
    The engine coolant temperature (ECT) is more than 68°C (154°F).
    The short term fuel trim is between -3 and +3 percent.
    The fuel trim is in cells 4, 5, or 6.
    Conditions for Setting the DTC
    Passive Tests
    During the operation of the AIR pump, the HO2S voltage for both fuel control sensors is above 300 mV for 12 seconds, 350 mV for 9 seconds on a hot start.
    When the AIR pump is turned OFF, the HO2S voltage for both fuel control sensors is below 600 mV for 25 seconds, 7 seconds on a hot start.
    The condition is present for 3 occurrences.
    Active Test
    The HO2S voltage for both fuel control sensors is above 250 mV for 3 occurrences.
    Action Taken When the DTC Sets
    The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
    The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
    Conditions for Clearing the MIL/DTC
    The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
    A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
    A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
    Clear the MIL and the DTC with a scan tool.
    Diagnostic Aids
    An intermittent may be caused by any of the following conditions:
    Low system air flow may cause this DTC to set.
    Excessive exhaust system back-pressure
    Moisture, water, or debris ingestion into the AIR pump.
    Pinched, kinked, heat damaged, or deteriorated hoses or vacuum lines
    Restrictions in the pump inlet, duct, or filter
    If the condition is intermittent, refer to Intermittent Conditions .
    Step
    Action
    Yes
    No
    Schematic Reference: Engine Controls Schematics
    1
    Did you perform the Diagnostic System Check-Engine Controls?
    Go to Step 2
    Go to Diagnostic System Check - Engine Controls
    Is the AIR pump fuse OK?
    Go to Step 3
    Go to Step 14
    3
    Did DTC P0412 or DTC P0418 also set?
    Go to DTC P0412 or DTC P0418
    Go to Step 4
    4
    Install the scan tool.
    Turn ON the ignition, with the engine OFF.
    Command the AIR system ON and OFF with a scan tool.
    Does the AIR pump turn ON and OFF?
    Go to Step 9
    Go to Step 5
    5
    Important
    Refer to Electrical Center Identification Views in Wiring Systems for relay terminal identification.
    Turn OFF the ignition.
    Remove the AIR pump relay.
    Probe the AIR pump relay B+ supply circuit terminal on the switch side of the relay using the J 34142-B Test Lamp connected to a good ground. Refer to Using Connector Test Adapters in Wiring Systems.
    Does the test lamp illuminate?
    Go to Step 6
    Go to Step 16
    6
    Jumper the B+ terminal to the AIR pump feed circuit at the relay harness connector using a fused maxi 40-amp jumper wire.
    Does the AIR pump turn ON?
    Go to Step 22
    Go to Step 7
    7
    Ensure that the jumper still installed.
    Disconnect the AIR pump electrical connector.
    Probe the AIR Pump Supply Voltage circuit at the AIR pump electrical connector using the J 34142-B Test Lamp connected to battery ground. Refer to Using Connector Test Adapters in Wiring Systems.
    Go to Step 8
    Go to Step 17
    8
    Connect the J 34142-B Test Lamp between the AIR Pump Supply Voltage circuit and the ground circuit of the AIR pump harness connector.
    Go to Step 24
    Go to Step 18
    9
    Disconnect the vacuum source from the AIR solenoid valve. Refer to Secondary Air Injection (AIR) Vacuum Control Solenoid Valve Replacement .
    Connect a vacuum gage to the vacuum source.
    Start and idle the engine.
    Does the vacuum gage display engine vacuum?
    Go to Step 10
    Go to Step 21
    10
    Connect the vacuum source to the AIR solenoid valve.
    Disconnect the vacuum hose to the AIR shut-off valves at the AIR solenoid valve.
    Connect a vacuum gage to the AIR solenoid valve port.
    Command the AIR system ON with a scan tool.
    Go to Step 11
    Go to Step 23
    11
    Inspect the vacuum lines to each AIR shut-off valve for the following conditions:
    Kinks
    Restrictions
    Poor connections
    Damage
    Leaks
    Did you find and correct the condition?
    Go to Step 21
    Go to Step 12
    12
    Disconnect both AIR intermediate hoses/pipes from the AIR shut-off valves.
    Is air pressure present at both hoses?
    Go to Intermittent Conditions
    Go to Step 13
    13
    Inspect for restrictions, poor connections, or damage at the following locations:
    The AIR inlet hose and AIR outlet hose from the AIR pump
    The AIR intermediate hoses/pipes
    The AIR crossover hose/pipe
    The AIR pump
    Repair as necessary. Refer to Secondary Air Injection (AIR) Pump Outlet Pipe/Hose Replacement , Secondary Air Injection (AIR) Crossover Pipe/Hose Replacement , Secondary Air Injection (AIR) Pump Intermediate Pipe/Hose Replacement - Bank 1 , Secondary Air Injection (AIR) Pump Intermediate Pipe/Hose Replacement - Bank 2 , or Secondary Air Injection (AIR) Pump Replacement .
    Go to Step 26
    14
    Remove the AIR pump relay from the underhood electrical center.
    Remove the AIR pump fuse from the underhood electrical center.
    Probe the battery feed terminal for the AIR pump relay harness connector with the J 34142-B Test Lamp connected to B+.
    Go to Step 19
    Go to Step 15
    15
    Disconnect the AIR pump harness connector at the pump.
    Probe the AIR pump supply voltage circuit at the harness connector with the J 34142-B Test Lamp connected to battery voltage.
    Go to Step 20
    Go to Step 25
    16
    Repair the open circuit between the fuse and the relay. Refer to Wiring Repairs in Wiring Systems.
    Did you complete the repair?
    Go to Step 26
    17
    Repair the open circuit between the AIR pump and the AIR pump relay. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 26
    18
    Repair the poor ground connection or the open ground circuit. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 26
    19
    Repair the short to ground in the ignition feed circuit. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 26
    20
    Repair the short to ground in the circuit between the AIR pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 26
    21
    Replace the vacuum hose or vacuum check valve as necessary.
    Did you complete the replacement?
    Go to Step 26
    22
    Replace the AIR pump relay.
    Go to Step 26
    23
    Replace the AIR solenoid valve. Refer to Secondary Air Injection (AIR) Vacuum Control Solenoid Valve Replacement .
    Go to Step 26
    24
    Inspect for poor connections at the AIR pump electrical connector. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
    Repair the poor connection as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
    Go to Step 26
    Go to Step 25
    25
    Replace the AIR pump. Refer to Secondary Air Injection (AIR) Pump Replacement .
    Go to Step 26
    26
    Clear the DTCs with a scan tool.
    Turn OFF the ignition for 30 seconds.
    Start the engine.
    Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
    Does the DTC run and pass?
    Go to Step 27
    Go to Step 2
    27
    With a scan tool, observe the stored information, Capture Info.
    Does the scan tool display any DTCs that you have not diagnosed?
    Go to Diagnostic Trouble Code (DTC) List
    System OK
    Sep 2003
    Metro ATL
    4,854
    Re: PCM Code P0410
    A wire knocked loose? Possible but it would almost have to be intentional.
    Have you driven the car far enough long enough to get the engine running up to normal temperatures? Clear the code, take a 20 mile drive in the snow and freezing rain and see if the code returns.
    The system is called secondary air injection and all it does is pump air into the exhaust manifolds to get the catalytic converter heated up when the engine is operating in open loop mode.
    2002STSPa's Avatar
    Mar 2007
    Pittsburgh, Pa
    29
    Re: PCM Code P0410
    Quote Originally Posted by CadillacETC1997 View Post
    Couldn't respond to your PM (I dont have 50 posts yet), check your email.
    2002STSPa's Avatar
    Mar 2007
    Pittsburgh, Pa
    29
    Re: PCM Code P0410
    Quote Originally Posted by JimD View Post
    I was on my way to a fine gentlemen's establishment with a few colleagues quite a drive from my humble abode when it the code went. I saw there is a TSB on it related to water getting in and shorting out the whole mess. That is probably what it is. I was hoping to luck out and get an easy fix.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Re: PCM Code P0410
    Those do have a tendency to suck up water, the problem is the hose inside the left fender.
    It has a screen on it and if water splashes up inside the fender (actually behind the inner fender which is not overly common) but it won't keep out water. If you splash enough water up in there when the engine is running cold or if water gets into the hose and then the car sits and you start it the pump will come on, gulp up that water and kill itself.
    This pump is the AIR pump. Sometimes referred to as the SAI pump.
    AIR (Air Injection Reaction or Secondary Air Injection) is a cold start device that pumps fresh air into a cold rich running engine to burn off extra hydrocarbons in "open loop" while the engine warms up. Then it shuts off.
    The new parts that the TSB speak about are designed to draw air from the engine air intake box rather than air from inside the fender so water is less likely to enter the inlet hose.
    You'll probably have to replace the hose and pump as outlined in the bulletin, then check the maxi-fuse in the underhood fuse block to be sure it didn't blow.
    There is one thing that can cause this code to set and a quick way to check it.
    If the car has been sitting and is nice and cold start the engine. If you hear a vacuum cleaner type sound that shuts off after about a minute, then the pump is running, if you don't hear that sound it is probably bad.
    If the hose is running, someone may have knocked one of the check valve vacuum hoses off. This will cause a vacuum leak and the check valves won't open, if the valves won't open the air from the pump can't get to the exhaust and the check engine light will come on.
    There is a valve mounted near the water pump cover and one at the rear valve cover. The vacuum control solenoid is mounted in the middle of the intake towards the rear underneath the engine cover. Remove the cover and follow the lines to be sure they are both connected at the check valves.
    If they are not, connect them and clear codes.
    If they are connected and you don't hear the sound, you need to replace the AIR pump and install the new hose.
    HTH
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Re: PCM Code P0410
    I'm seeing a similar problem, and have tried the suggestions on this thread without a solution. I'm getting an intermittent P1416 code (sets about once every 5 driving cycles). The code will set when the engine is warm, and when driving at a steady speed, usually over 35 mph.
    The computer is not setting any other codes. I hear the vacuum cleaner sound on startup, and have checked the vacuum lines (they were in place and looked OK)
    Other symptoms: When starting from cold, the car will either stall or near stall when idling (like at a traffic light) and the temp gauge is at the first mark (1/8). The car will not do this again for the rest of the drive, or when started warm/hot. This only happens when the car is almost completely cool.
    Also noted: an intermittent hesitation to accelerate (like a bog) when cruising and light to moderate throttle input is requested. Almost feels like the transmission is taking its time deciding whether to unlock the torque converter or not. Heavier throttle input does now show this behavior.
    What I've replaced on the car since I got it 6 months ago @ 91,250 miles (car now has 100,600 miles):
    Spark plugs (used AC Delco 41-950), no wires to replace
    Pre cat O2 sensors
    Center engine mount (by radiator)
    Crankshaft position sensors (was getting p0385 error code)
    Coolant drained and refilled with DexCool mix
    Oil changed, now at 70% life remaining
    Fuel Pressure regulator
    MAP sensor (was getting intermittent MAP too high error)
    Throttle body cleaned, GM TEC used on engine as per procedures listed elsewhere on these forums.
    Any ideas on how to proceed? I don't have a tech 2 to use.
    rwilly is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Seville STS
    Sep 2011
    Ohio
    23
    Re: PCM Code P0410
    Okay guys I have a silly question?I have a 2001 Seville STS with116,250 on the clock. I changed the intake manifold gaskets and the plenum and cleaned the throttle body. The TB was pretty gummed up.Back to the question I started it after putting it back together and no problems ran smooth and idled at about 650 t0 700.Didnt sound as though any vacum leaks or anything like that.Drove it today about 10 miles and checked to see if any codes.Came up with a PCM P0410.I know its related to the air pump but is it something I could have did?Loose vacum line or anything else to look at.Ran great when I took it out and still is cant even hear it running or no vibtration what so ever sitting idling.Hell I even had to look at the tach to make sure it was running.The only reason I replacedthe plenum and intake gaskets was I read that if the plenum has a tear in it It could affect gas mileage.I noticed a drop in mine since I got it I was getting around 16.5 in the city and alot better on the highway when I can keep my foot out of it.Thats the reason for replacing it and since I had the intake off better off changing those too. Big question is could it be 1 of those little lines running off the back head?I might have missed a crack or pinched one is that possible?
    Thanks for any help you guys can give me. And yes I know if it aint broke dont fix it just wanted to know why gas mileage was dropping and yes there was a small tear in the plenum.
    Again Thanks you guys are the greatest when it comes to Caddys.
    reese5997 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac SLS
    Feb 2012
    31
    Re: PCM Code P0410
    I have been fighting this code for the last three weeks. I replaced my pump, both solenoids, and the censor and nothing. Today, I took my car to a auto hobby shop and put it on a lift. because all the moving parts had been replaced, the only thing left was the non-moving parts. As I inspected the hose lines, I discovered that the hose that connects the front solenoid to the pump was crimped and was wedged between the engine cradle and the chassis. Hose was replaced. Problem solved. hope this helps.
    dewhurstaj is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldorado ETC & 1997 Seville STS
    Jun 2009
    Kokomo, IN
    104
    Re: PCM Code P0410
    I had a radiator replaced on my 2002 Eldo & now I am getting the infamous PCM P0410 fault code.
    1. Where do I go from here?
    2. Location of the fuse
    3. Can someone please provide a pic of the pump & location of the hose that I can inspect?
    Thanks for helping!
    Andy
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,197
    Re: PCM Code P0410
    You will never get answers for the AIR system here. Next time, try the Seville/Eldorado forum.
    The mechanic probably did not re-connect AIR control valve #2, right over/next to the lower radiator hose. Check the vacuum solenoid and tubing from the throttlebody to the solenoid/T to both AIR valves. The AIR pump itself is down on the frame flat inboard and in front of the LF wheel. Your owner's manual fuse/relay box descriptions will give the fuse location. The pump relay is the small gray box with blue connector clipped to the right strut tower.
    Depending on ambient temperature the AIR system will operate for from 10 - 40 seconds at cold start to quickly light off the cat - it sends fresh air to the exhaust manifolds to continue the fuel burn.
    Pictures and diagrams in Cadillac Tech Tips. Google "cadillac forums 2002 eldorado AIR pump" or something close.
  15. Remove Advertisements
