  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Electrical Technical Information
Electrical Technical Information Section for discussions in regards to electrical systems.
Cadillac Forums: radio display issue - help!
Old 03-04-07, 01:36 AM
lochenjons's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1985 Cadillac Fleetwood Brougham d'elegance - 1969 Coupe DV
View lochenjons's Photo Album
Casino Cash: $3298
Angry radio display issue - help!
okay so i went to the pick n pull today to get a new radio. my old one works fine except for the fact that the display doesn't work. (see picture)
i tried to put the radio from the pick n pull in and the sound was worse than on my radio (i guess DNR does make a difference) so i took that radio out and decided to put mine back in. before i put it in, i dismantled it and checked the connections thinking it could possibly be a short circuit or something like that causing the issue. i reassembled it and stuck it in my car. presto! it worked! for about 5 minutes the display was fine. i could read every digit crystal clear. then it cut off the top part of each digit. hmm. its working better than it was working before (see pic again) and i can actually tell what time it is. i really need help on this, i know my radio is capible of producing readable digits, what should i do?
  #2 (permalink)
Old 03-09-07, 03:04 PM
Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante
View carnut's Photo Album
Casino Cash: $8920
Re: radio display issue - help!
This is usually a sign of a cracked solder connection on the terminal board. Remove the radio, remove the top lid and touch all solder connections with a soldering gun. Sometimes re heating the solder will fill a crack. Be very careful that you dont spread the solder, simply get it hot. What you probably did was flex the board during reassembly and that corrected for a few min. the display. Most any radio you get from a wrecking yard will have this problem, was very common after 5 to 8 years to fail like this
  #3 (permalink)
Old 03-13-07, 12:49 AM
lochenjons's Avatar
Casino Cash: $3298
hey dude thanks a bunch, totally fixed the problem. i took it out and filled in a few holes and cracks and now it works great! thanks again
  #4 (permalink)
Old 03-13-07, 12:20 PM
Casino Cash: $8920
Glad I could help. Thanks for reporting back on the repair. might help someone else!
Tags: , ,
display, issue, radio
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
