Results 1 to 3 of 3
Thread: Creative Steel Engine Mounts!
    Creative Steel Inc's Avatar
    Creative Steel Inc is offline Cadillac Owners Member
    Automobile(s): 04 CTSV
    Jul 2013
    58
    Our urethane mounts are a direct replacement for worn factory mounts. They will fit just like the factory mounts with no other modifications. The factory mounts are designed as a rubber bladder with liquid in them to create the soft, comfy feel of the Cadillac. After these mounts have had some miles on them, they crack and leak out the liquid creating a blown motor mount. You will notice if your engine mounts are bad by how your car turns off. If your vehicle rumbles to a stop like a diesel engine, your engine mounts are shot.
    What sets our mounts apart from our competition is our engine mounts have a two-part interlocking steel framework encased in urethane to give engine support in both directions of push and pull. When the engine tries to twist under acceleration the driver's side of the engine tries to lift, putting that mount in tension (pull apart) and the passenger side mount in compression (push together). Then, when you gear down into a corner or to stop, these forces are reversed. Our mounts are correctly designed and take both of these forces into account. Our mounts have pins on both sides of the mount that fit into the factory location of the mounting bracket. They also come with aluminum heat shields.
    We are now selling two different hardness' of urethane for these mounts:
    Daily Driver/Street(BLACK): For those who want to replace the factory mount with something stronger that will hold up to the power of the V8, but still want to maintain the noise and vibration feel of OEM.
    Race(RED): For those who use their vehicle at the drag strip or autocross and/or don't mind the added noise/vibrations.
    Our products are available at: https://creative-steel.com/store/index.php
    Open Monday-Friday 8:00-5:00pm PST
    Phone: 503-316-1811
    Fax: 503-316-1814
    Kristie@Creative-Steel.com
    Website: https://creative-steel.com/home.php
    Follow us on Facebook!: https://www.facebook.com/pages/Creat...39612609499435
    3859c1's Avatar
    3859c1 is offline Cadillac Owners Member
    Automobile(s): 2006 STS
    Nov 2013
    Dewitt, IA
    39
    Are these available for the 3.6L engine?
    Jul 2013
    58
    Re: Creative Steel Engine Mounts!
    Quote Originally Posted by 3859c1 View Post
    Yes they are, check our website. Not sure of the SKU # off hand but they are on the site.
    Phone: 503-316-1811
    Fax: 503-316-1814
  • You may not post replies
