Results 1 to 5 of 5
Thread: 2015 Mustang Fully Revealed
    AutoGuide.com is offline Moderator
    Automobile(s): None
    Dec 2012
    127
    The 2015 Ford Mustang has been fully revealed, ushering in a new generation of the American automaker’s signature sports car.
    Sporting an all-new chassis, the 2015 Ford Mustang has seen its roof lowered 1.5 inches, the hood 1.3 inches and the dashboard about 2.8 inches for a much sleeker design compared to its predecessor. It also sports independent rear suspension, a first for the storied Mustang. While traditional Mustang enthusiasts will groan over the thought that the Mustang no longer has a solid rear axle, Ford promises that the independent rear suspension improves handling, ride and steering precision on the all-new ‘Stang.
    As for powerplants, the 2015 Mustang will come standard with a 3.7-liter V6 with 300 hp while a 2.3-liter turbocharged four-cylinder EcoBoost engine will be available with at least 305 hp, according to Ford. Then of course, there’s the top-of-the-line 5.0-liter V8 that will be rated at “more than 420 hp,” though official specifications have not been announced.
    Tweaks were also made to the front roof pillars in order to offer better front visibility on the 2015 Mustang while the passenger airbag has been moved to the glove box door, getting rid of the separate panel typically found on the dashboard. As for the convertible model, which will be released nearly at the same time as the coupe, Ford boasts that it’ll have the fastest top on the market lowering or raising in just seven seconds. The convertible will be operable at speeds up to 5 mph.
    And while minor, it’s worth mentioning that the 2015 Mustang’s front seats now feature “memory recline,” which will return to the driver’s preferred seating position after being moved forward in order to get the rear passengers out of the coupe.
    See more 2015 Ford Mustang photos at AutoGuide.com
    HR-cts is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS4 wagon 3.6
    Nov 2013
    Ontario
    129
    Re: 2015 Mustang Fully Revealed
    will wait for the boss 302 version to see if it's worthwhile to trade in my 2012 boss 302.
    shape is more fluid than the past version...looking good.
    remains to be seen if the irs is sorted out properly...i'm not holding my breath on that one.
    ford probably should have hired a contractor, like lotus, to make the suspension perfect for the first year model.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    I still want to see the turbo 4 motor set up
  5. #4
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Still looks like a Nissan Z with a Honda front end to me.
  6. #5
    orconn's Avatar
    orconn is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac 95 STS, 02 SLS
    Oct 2007
    Midlothian, VA
    73
    13,792
    From looking at the pup, I'd have to say that bitch sure got around! Lot of fathers in on that concoction.
  • You may not post replies
