Help me with a weird vibration in my '91 LeSabre.
Results 1 to 8 of 8
Community Lounge, Introductions and General Discussion Discussion, Help me with a weird vibration in my '91 LeSabre. in General Discussion; Just recently, my '91 LeSabre started to shake at certain speeds. It does it in the 40mph range as well ...
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Dec 2004
    Roseville, MN.
    29
    34,087
    Just recently, my '91 LeSabre started to shake at certain speeds. It does it in the 40mph range as well as the 55mph range. It doesn't matter if I'm accelerating, cruising or braking or if I've got the wheels turned or straight. I can feel it in the steering wheel and in the floorboards.
    My first thought is my tires are off balance, which is no worry. Am I right in thinking it's the tires, or does it sound more severe?
    68
    81,750
    Re: Help me with a weird vibration in my '91 LeSabre.
    Tire balance would be my first guess.
    HAZZARDJOHN's Avatar
    HAZZARDJOHN is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 Coupe deVille d'Elegance, 05 Lesabre,91 Suburban 4x4
    Jun 2007
    Medieval England Iowa
    773
    easy way to tell if it is the tires, rotate them. If the vibration changes it's more than likely the tires or in need of an alignment. If it doesn't change it could still be the tires or an alignment issue but if it changes it gives you a good place to start. Plus it's free.
  5. #4
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Quote Originally Posted by I~LUV~Caddys8792 View Post
    You can think that but you won't know unless you try something as suggested.
  6. #5
    Aron9000's Avatar
    Aron9000 is offline Cadillac Owners Master
    Automobile(s): Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
    Jul 2008
    Nashville, TN
    5,418
    Check if you're missing any wheel weights. The old style ones that clamp to the edge of the wheel don't generally fall off, but those newer stick on types are known for it.
  7. #6
    Dec 2004
    Roseville, MN.
    29
    34,087
    I have the older clamp-on style ones still attached. Maybe I had the stick on ones as well that fell off without me knowing it.
  8. #7
    truckinman is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac STS 3.6
    Apr 2012
    Columbus OH
    31
    1,219
    How old are your tires? Could be uneven wear on one of the tires due to over or under inflation. Do you feel it in the steering wheel, or just a resonating vibration through out the car?
    Just read it again and saw you feel it in the steering wheel too. Lol. Yea I'd def say one of your fronts is off balance either due to lost weight or uneven wear
  9. #8
    Dec 2004
    Roseville, MN.
    29
    34,087
    I'll get them rotated at work this week. It's due for that and an oil change too.
  10. Remove Advertisements
