Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Generator Question
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    Generator Question
    I have a small shed in my back yard. Its not a tiny metal garden shed but about 14 ft by 14 ft. its made of brick etc and has outlets and light fixtures built in already.
    The problem is that the wires which fed the building power were cut and the meter box disabled.
    We were originally going to wire the building back to the box. He said we'd have to call in the power company, buy a box, buy a meter etc etc and it would run into the 1/2000 range. I kinda felt it was a cop out because i had a hard time getting him there in the first place. Anyway he mentioned buying a generator which actually doesnt sound like a bad idea.
    I do however need to make sure im understanding the way a generator works correctly.
    Is it possible to connect a generator directly to the buildings power supply. There are a couple of light fixtures and a couple of outlets.
    What kind of generator would i need?
    At most i would want a good bright light to work at night with
    An outlet to hook my polisher, vac, portable shop lights or even a fan up to
    any advice would be appreciated
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Re: Generator Question
    A generator in the 4500 Watt range would work, BUT at today's gas prices you'd go broke if you did much nighttime work, and a decent, reliable unit is not cheap. For a portable generator the 115 volt AC wiring hookup is usually one or more 20 amp 3-wire wall sockets, a 30 amp 3-way locking outlet, and maybe a 12V DC outlet
    Why not get into the shed wiring, separate the electrical sockets from the lighting bus, and simply run a couple of marine grade 14 gauge 3-wire extension cords to the shed. Portable. (If the wire run is over 100 feet that compounds the problem.)
    Surf through the Northern Tool website for both generators and contractor grade HD extension cords - the heavier the wire gauge, the less voltage/current drop per length.
    Jul 2005
    Fayetteville NC
    33
    4,513
    its WAY over 100 ft away. probably a football field away
  5. #4
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Your too honest for your own good, sometimes it doesn't pay to get local (he said ?) involved, I'm not saying a shoddy repair should happen, but I'm sure someone could do a proper and safe repair,
    Dont get involved with a generator, it's another machine too contend with.
  6. #5
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    Or think a little farther outside the box...
    http://www.discountpv.com/index.htm solar & wind options on a more personal scale.
  7. #6
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    I must be the only one that thinks 1-2k to completely refurbish the wiring out to such a far away shed, plus the meter installation and everything that goes with it isn't that bad...
    I mean, unless a quality generator can be had for like 500 bucks what's the point of going with that alternative in the first place, plus the fuel to run it, plus the maintenance associated with a mechanical device that won't get frequent use. A couple grand sounds mighty good to me to avoid all of that nonsense.
  8. #7
    Jul 2005
    Fayetteville NC
    33
    4,513
    Dont get me wrong, i totally agree, if it was MY house. We're renting the place, and though we plan to stay for a while, its still not mine.
  9. #8
    Dec 2007
    5,630
    Can the shed be moved closer?
  10. #9
    Jul 2005
    Fayetteville NC
    33
    4,513
    no unfortunately. Its a small brick building complete with a foundation.
    Sent from my Dell Streak
  11. #10
    Playdrv4me's Avatar
    Nov 2003
    11,694
    Ahh, I missed the rental part. Now I understand!
  12. #11
    Jul 2005
    Fayetteville NC
    33
    4,513
    my fault, i didnt mention it.
    On the flip side, we DO plan on staying for a few more years, and yesterday I almost felt like calling the damn power company myself. Our landlord would probably either help with some of the costs or deduct it from rent for a while. Maybe I'll at least call to see what it would actually cost.
    So, I bought a new window switch for the allante, I installed it and the passenger window started going crazy, which meant something inside the switch was stuck, easy fix. Bad thing is its a bad idea to take a window switch apart in the dark. I had to drive the SRX all the way back to our place, take it apart in the house, make an adjustment, then drive it back to the shed/car. My adjustment wasnt enough so i had to drive back and forth a few times. The allante is up on jackstands so i couldnt just drive that up closer. it was VERY frustrating
  13. #12
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    If you do go the generator route, I use a Craftsman 3500W /5000 Surge watts generator at work. (Doesnt sound like alot but the thing really delivers) I think it has a 7 hp OHV 1cyl engine. I have used a pipe threader (1500watts), jackhammer (900w), drills/sawzalls (300?w each), and a radio all at the same time without it breaking a sweat. Some generators even have idle speed control to conserve gas when not under load. Unless you're using the shed as a full time machine shop, I think a genny like mine or one a bit bigger, plus a couple heavy gauge extention cords would suit your needs well. Its also a good investment in case of emergencies. AND, unlike a permanent installation, you could always sell the genny and get some of your money back if/when you move out.
  14. #13
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    If you bought a used generator you could probably sell it again for what you paid. People like me have one to deal with power outages to drive the sump pump, furnace fan, wife's curling iron etc.
  15. #14
    Oct 2008
    Palm Bay, FL
    2,024
    Or - Wait for a hurricane, then come down to Florida and flip it for DOUBLE what you paid!
  16. #15
    Jul 2005
    Fayetteville NC
    33
    4,513
    ok, so there are a couple of 3500w generators im checking out. If i go that route, will i need to connect my stuff directly to the generator? or is there a way to connect the building to the generator and then connect my stuff to the building...
    the reason i ask is because the lights have switches mounted into the wall also, there are outlets in convenient places in the building.
  • You may not post replies
