1972 Deville starter/shims problem
Results 1 to 3 of 3
The Classic Cadillac Forum Discussion, 1972 Deville starter/shims problem in Past Cadillac Vehicle Discussion; My starter keeps breaking because the shims aren't right. I have no idea what to do. I tried from having ...
    PosadaSD619 is offline Cadillac Owners Member
    May 2014
    21
    My starter keeps breaking because the shims aren't right. I have no idea what to do. I tried from having none to putting three on. Anyone know what I can do?/ had this problem before?
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: 1972 Deville starter/shims problem
    If your timing is too far advanced that will also break starters. Check your timing. Then maybe loose bolts, wrong bolts. Flywheel the wrong one or damaged.
    chrisntam is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Deville Convertible
    Oct 2012
    North Texas
    309
    The starter on my '70 has no shims. It also has two bolts that bolt it to the block (by the nose cone) + a bracket on the back of the starter that is about 2" to 3" long that also bolts to the block. I hear (no first hand experience) that if you don't have that rear bracket, over time, your starter will break. Do you have it mounted using three mounting points?
