1964 429 question
Results 1 to 8 of 8
The Classic Cadillac Forum Discussion, 1964 429 question in Past Cadillac Vehicle Discussion; if i let it idle for a few mins ill get slight white smoke. its deff oil. if i rev ...
    superjeep is offline Cadillac Owners Fanatic
    Automobile(s): 68 sdv,63 sdv,64 fleetwood,60 fleetwood,66 fleetwood
    Jun 2013
    34
    107
    1964 429 question
    if i let it idle for a few mins ill get slight white smoke. its deff oil. if i rev it ill get a light puff but seems fine when driving. it runs amazing. my 68 472 did something similar and it turned out to be valve seals. i used 67 429 umbrella seals on it. is the 64 429 seals different from the 67 429? or is there any common things to burn a little oil?
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: 1964 429 question
    Between 64-67 everything on the motor is the same.
    seat angle-- 45 degrees
    face angle--44 degrees
    valve lift intake--.440 in.
    valve lift exhaust--.440
    valve spring pressure (valve open) lbs@in.--160@1 1/2
    valve spring installed height--1 15/16 in.
    stem to guide clearence-(intake .0005-.0025)(exhaust .0010-0025) in.
    Stem diameter- (intake .3420)(exhaust .3420)
    The only things that were different those years was, series 67 and 75 use 1 1/2 qt of coolant, and some amps on alternator at rpms.
    Jun 2013
    34
    107
    Only reason I ask is,if you look up 64 429 seals they look like o-rings. If you look up 67 429 seals they are the umbrella seals
    CaddyGas's Avatar
    Jun 2012
    454
    Try RockAuto... http://www.rockauto.com/dbphp/x,carc...Stem_Seal.html.
    I think Summit Racing has some, I know they got Chevy not sure about Caddy.
    Jun 2013
    34
    107
    yeah i found both styles. just wondering if i can use the 67 style because I've had good luck with them. or if I'm stuck with the 64-66 style. or if thats even my problem hahaha
    CaddyGas's Avatar
    Jun 2012
    454
    Using the 67 style is fine, in the motor there's no difference.
    P.Katson is offline Cadillac Owners Member
    Automobile(s): 1966 Eldorado
    Oct 2007
    San Diego
    53
    Dont overlook a bad transmission vacuum modulator as a cause for the smoke.
    Jun 2013
    34
    107
    Just did that. Its deff an oil smell
  11. Remove Advertisements
