New Owner
Results 1 to 13 of 13
The Classic Cadillac Forum Discussion, New Owner in Past Cadillac Vehicle Discussion; Looks like I will be the proud owner of a '70 Coupe Deville. The car has been sitting in a ...
    1323baxley is offline Cadillac Owners Member
    Automobile(s): 1978 Eldo Biarritz
    Jun 2014
    TEXAS
    27
    New Owner
    Looks like I will be the proud owner of a '70 Coupe Deville. The car has been sitting in a garage unused for 22 yrs. Interior and Exterior is excellent. I know there are some things that I need to address first. Im not even sure where to begin tho... Any help is appreciated
    HansH is offline Cadillac Owners Member
    Automobile(s): Deville Convertible
    Jun 2014
    22
    Re: New Owner
    Hi!
    I`m quite new to the Cadillac`s myselfe, but I think the best thing would be to get a service manual.
    I bought a -69 DeVille Convertible a week ago, and I`m waiting for the manual to be delivered
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Re: New Owner
    A little mechanical freshening and the car will be good to go. Congrats on your new Cadillac!
    Caddycruise is offline Cadillac Owners Member
    Automobile(s): 1975 Eldorado Convertable and hardtop
    Jun 2014
    31
    Re: New Owner
    A good going over it wouldn't hurt. I'd start with changing out all the old fluids. Check your brakes to make sure they are not frozen up. If it has not been started for a long time you might have to drop your gas tank and get rid of all the old gas. In addition I'd pull the plugs and drop some motor oil down in the cylinders and crank it over a few times with the plugs out just to make sure your cylinders are not rusty. A friend of mine had to disassemble his old Mach 1 Mustang because it locked up the engine due to the cylinders being varnished into place. Hopefully that won't be your problem. Replace any old vacuum lines or hoses in general if they are cracked or dry rotted. Same goes for the tires. If you see cracks on the sidewalls they can blow out at anytime. I actually had an old tire do this just sitting in place in the driveway. Start out with small trips around town and you will start to figure out what else needs attention. Also use some sort of gasoline additive to compensate for the lack of lead and ethanol additives in todays gasoline. Run Super Unleaded. Have fun. You will probably never drive a more comfortable car. Think of driving your couch down the street.
    disturbio's Avatar
    disturbio is offline Cadillac Owners Fanatic
    Automobile(s): 1969 DeVille convertible, 72 sdv - RIP
    Apr 2013
    az
    35
    182
    Re: New Owner
    Go through all the front end before you drive it regularly. The weight of that 7.7 and six foot hood eats up 45 year old plastics
    Jun 2014
    TEXAS
    27
    Re: New Owner
    Awesome, guys! thanks for the encouragement. Im sure ill be on here quite a bit
    Jun 2014
    TEXAS
    27
    Re: New Owner
    I'm going to do my posts in reverse. Tell me what you notice about this engine... Deville Engine.jpg
    Jun 2014
    TEXAS
    27
    Re: New Owner
    I'm going to do my posts in reverse. Tell me what you notice about this engine... Attachment 225866
    orconn's Avatar
    orconn is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac 95 STS, 02 SLS
    Oct 2007
    Midlothian, VA
    73
    13,792
    Re: New Owner
    It's missing its' air cleaner?
    Jun 2014
    TEXAS
    27
    Re: New Owner
    there's one right answer!
    anything else you notice?
    Cady70's Avatar
    Cady70 is offline Cadillac Owners Member
    Automobile(s): 70 Deville, 90 Allante
    Dec 2012
    SC
    46
    46
    Re: New Owner
    You have a hole on the evaporator/heater core cover. Missing mix door actuator.
    Jun 2014
    TEXAS
    27
    Re: New Owner
    Things i noticed magnified....
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: New Owner
    The missing mix door actuator was mentioned already.
    I bet that hose connects to the missing air cleaner.
  16. Remove Advertisements
