Lower ball joint 1970 Eldorado
Results 1 to 7 of 7
The Classic Cadillac Forum Discussion, Lower ball joint 1970 Eldorado in Past Cadillac Vehicle Discussion; The dust cap of the lower ball joint on my 1970 Eldorado is damaged. I want to replace it . ...
    Rdtreur is offline Cadillac Owners Member
    Automobile(s): 1970 Eldorado, 1968 DeVille convertible
    Dec 2013
    Amsterdam, the Netherlands
    38
    68
    The dust cap of the lower ball joint on my 1970 Eldorado is damaged. I want to replace it . Can I just unbolt the 2 side bolts and 1 top bolt? Or do I need to take out the drive shaft and "spindel"/bearing assembly?
    Many thanks, ramon
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Re: Lower ball joint 1970 Eldorado
    If I remember correctly I did the ball joints without removing the drive shaft. But it is a long time ago.
    When I did it, I replaced all upper and lower balls & knuckles and had everything disconnected. But I am almost sure the shaft was not out.
    Dec 2013
    38
    68
    Thanks for the info. I think I will just start wrenching and see how it go's.
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Quote Originally Posted by Rdtreur View Post
    That's how I did it, because I did not have my shop manual yet back then.
    Good luck!
    Dec 2013
    38
    68
    I just got the lower pherical ball joint loose but I can't get the lower ball joint off the A-arm. The driveshaft is in the way :-(.
    Can some one please tell me if there is a way to take off the lower ball joint without removing the whole lower a-arm, torsion bar and steering knuckle? The book says that basicly the whole front suspension needs to dismantel to take out a ball joint but I do not have to remove the rivets in the A-arm. There is already a bolt-in-type ball joint.
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Can't you remove the A-arm to work on it?
    Dec 2013
    38
    68
    I unbolted the upper a arm and steering knuckle. This way i was able to change the dust cap... A Whole lot of work :-((
  10. Remove Advertisements
