Lazy man's way to check for an exhaust leak
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Jeff R
The Classic Cadillac Forum Discussion, Lazy man's way to check for an exhaust leak in Past Cadillac Vehicle Discussion; Yep, the old "Leaf Blower Up the Tailpipe" trick. Figured it was an easier and cooler way to check. Jeff...
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    539
    Jeff
    FoxRodder likes this.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: Lazy man's way to check for an exhaust leak
    Jaykeane is offline Cadillac Owners Member
    Automobile(s): 73 LD Ragtop
    Sep 2012
    40
    nothing beats a length of (CLEAN) small diameter hose..
    carefully poke one end in your ear, and wave the other end near where you'd expect a leak.. (manifold flanges and joints).. works for vacuum leaks as well.. you'll really hear them.. (engine running obviously)
    I use a mechanic's stethoscope with the metal probe removed.. just the hose part.. look at one, and you'll see what i mean..
    the leaf blower idea scares me.. imagine all the pieces of rust and debris that you could be shooting past an open exh. valve and into the comb. chamber..
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    41
    4,023
    Is the engine not running? You could have one blocking the exhaust intermittingly while you check from front to back while the egnine is running?
    unautherized is offline Cadillac Owners Member
    Automobile(s): 1978 Eldorado biarritz
    May 2012
    38
    This reminds me of a joke where a guy said He was going to go blow up a bus, and came home with soot on his lips! LOL
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,854
    This thread is straight out of "There I fixed it" pages.
    rodnok01's Avatar
    Feb 2012
    NC
    6,626
    Yea I don't think you want all that crap blowing back into the engine.... Slightly pressurizing would be one thing but that's a whole different critter.
    Jeff R's Avatar
    May 2013
    St. Louis
    47
    539
    No, the engine was not running. Turns out the leak is from the slip joint at the manifold. Too hot to reach up in there when it was running and with the fan blowing it was hard to tell where things were coming from.
    If you'll notice, it was a cordless blower. Battery was low so it wasn't full pressure blowing backwards.
    Jeff
  11. Remove Advertisements
